Warm (not hot) air from vent.
  • 416stroker
    • May 2008
    • 2448
    Your hoses are backwards /Tread. Its a 24valve swap peeps.
    Swap your hoses.
    84 318I Delphin RIP
    87 325IS delphin 24v Sold
    89 325 Alpineweiss
    • Rennsport
      • 2139
      I just went through my entire heating system trying to get mine to blow hot.
      Check the difference in temperature on the coolant pipes before and after the heater control valve. if its the same check the temperature difference between the input and return pipes for the heater core.
      If they are all cold, bypass the pressure bypass valve (your car may or may not have one, if it is a late model it will. Early model may have one if it was installed under warranty) Its located on the input hose coming from the back of the head to the top pipe of the heater core.
      Cheap fix if it is the heater control valve is bad: drill a hole through the solenoid. You'll always have heat, but you can just close the vents.
      m106 1990 e30
      e36 daily
      e32 cruiser
      • graphikg
        • Jan 2008
        • 1614
        Where is the heater valve and solonod?
        • 416stroker
          • May 2008
          • 2448
          How do you have you hoses? This the 24 valve swap right?
          Do you have them like this
          Originally posted by hugh jass
          The coolant hose off the back of the head goes to the bottom pipe on the firewall
          The coolant hose off the spider hose goes to the top pipe on the firewall
          84 318I Delphin RIP
          89 325 Alpineweiss
          • jeffw
            • 1087
            Check your thermostat. I have the same problem and I was told the thermostat could be bad or stuck open
            • graphikg
              • Jan 2008
              • 1614
              http://www.r3vlimited.com/board/show...t=heater+hoses
              Ya, I have the 24v swap. I saw the thread. My heater was blowing SUPER hot for a week or two until it started blowin almost warm at best. Do I have to drain the coolant to do this?
              • Moto-Mucci
                • 2058
                Got mine blowing hella hot again.
                Turns out my cables behind the HVAC panel just needed to be adjusted.
                I'd check that - it's an easy fix if they've just popped out of place. You just may not be opening the flap all the way.
                • 416stroker
                  • May 2008
                  • 2448
                  Are they wrong?
                  If so just crimp them before you take them off with vice grips if you dont have the correct tool.
                  84 318I Delphin RIP
                  89 325 Alpineweiss
                  • graphikg
                    • Jan 2008
                    • 1614
                    I may do this first. How do you "adjust" them?
                    Are they wrong?
                    Sad to say. Havent checked yet, job takes all my hours away.
                    • TDE30
                      • 7042
                      As elementary as it might sound, are you sure the temp isn't set to warm-hot? Even with the fan turned off, it will still allow warm air to pass through. I have noticed this in multiple cars, and I usually just set the temp to the midway point when the fan's not in use.
                      Your problem sounds more like the heater valve though. Best of luck.
                      - Trey
                      E90 325i/6 (ZSP, ZPP, ZCW)
                      E36 325i sedan
                      E30 325i sedan
                      Volvo 945T
                      • graphikg
                        • Jan 2008
                        • 1614
                        Just to update the thread... Aside from my Head gasket being blown, the hoses were backwards. The one in the back of the head was on the top, and the spider on the bottom - WRONG!
