Car Leaking Coolant
  • dr.gonzo
    • Nov 2009
    • 206
    Car Leaking Coolant
    Hey everyone,
    Well when I was on my way to the hardware store today a notice that once the car was off and stopped a large amount of coolant was coming out. It was from right around the drivers side front wheel. Any suggestions of what it could be?
    www.roadreview.net
  • Naplm00
    • Nov 2008
    • 1573
    im guessing a busted hose or cracked rad
    88 325ic ~~~> Rusty and ugly
    85 E ~~~> RIP
    • E30Kaiser
      • Mar 2008
      • 1790
      probably a hose, i had the same problem shortly after getting my car, took awhile to track it down but it was the hose in the end, had a gash in it where I assume the fan had hit it.
      "We're not here for a long time, we're here for a good time"-Colin McCrae
        • 34844
        open the hood and look?
        • SpecM
          • Oct 2005
          • 4531
          that would take less time than posting, yes?
          1989 cirrisblau-metallic 325i
          • kid325e
            • Sep 2007
            • 6422
            lower rad neck/hose is my guess.
            Now do as nando says and open the effin hood.. people these days.
            clutchCTRL!
            Move with a purpose.
            - 1991 325iX 4dr/5spd
            - 2000 323i AT
            2016 Mazda CX3 Sport AWD
            • graphikg
              • Jan 2008
              • 1614
              Sounds like coolant is coming from your reservoir overflow hose. See if there is a leak coming from the radiator or any of the hoses to the rad fom the motor or from the radiator. If not, it could be water boiling in your system and leaking out the overflow hose landing right by your wheel. This would happen due to a bad radiator cap. Check hoses for any leaks. If not any, replace your cap. Its about 15-20 bucks and easy to install :).
              • dr.gonzo
                • Nov 2009
                • 206
                Why do people think that just because I'm 19 I don't open the hood. I have taken apart motors, replaced plenty of parts. I just finished fabricating brackets for my sparco sprint v. Of course I pop the hood.
                www.roadreview.net
                • e30trooper
                  • 11576
                  I was out in the SFV area today but yea >>> Friday meet<<<
                    • 34844
                    nobody knew you are 19, genius. ;)
                    • 10Toes
                      Me Father Was A Tree
                      • Jan 2008
                      • 61222
                      Then why are you asking such a simple question and not giving a discription of the area it is leaking from.
                      • dr.gonzo
                        • Nov 2009
                        • 206
                        When I stopped the car and got out it was quite literally gushing coolant. Ironically enough I let the car idle for five minutes or so this morning while vigorously looking over the whole car for the leak with no avail. I will go run a few errands and check, I have a feeling if it didn't get warm enough to open the t-stat i might have come closer to isolating the problem. I also discovered my alternator is loose which adds one more to do. Also, what needs to be done in preparation for cleaning the engine bay? Is it the normal cover dist, fuse, all electrical parts essentially?
                        www.roadreview.net
                        • graphikg
                          • Jan 2008
                          • 1614
                          Where was coolant gushing from? If it wasnt leaking when still warming up, it could be the rad cap man. Just replace it for fun. And as far as cleaning the bay, cover the fuse box, alternator, and air box. Purple powa that puppy.
                          • dr.gonzo
                            • Nov 2009
                            • 206
                            Oddly enough today I could not get it to leak, The radiator doesn't have a cap on it. You mean the coolant reservoir? I changed the differential fluid today with castrol syntec of the correct weight. Made a HUGE difference as far as I can tell with how the car accelerates and how smooth the power is put down. Now I just need new differential mounts/bushings. Any suggestions?
                            www.roadreview.net
                            • e30trooper
                              • 11576
                              ehh I need to change my trans and diff oil... to lazy tho
