Ok 1st and most importantly,
-after seeing the car and testing it... car starts right up BUT turns out the "needs some tuning" as listed in the advertisment is due to the timing... engine is making a pretty audible clanking/clunking ticking type noise sounds like lifters or timing is off.... guy says when he installed a new cam (also did rocker arms, cam shaft oil seals, valve oil seal, gaskets, belts, radiator, hoses etc at same time) he didn't quite get it lined up right and now it makes that noise... he mentioned he followed the Bently manual as a novice DIY and purchased the alignment tool... just apparently didn't get it right? Lots of new engine parts though..... just that engine noise. However, it doesn't even seem to effect performance much (no stutters bogs or hesitation)
2nd,
2 cv boots are torn, still have grease in them but they just need new boots.
3rd,
the shifter is super super duper hard to move around... after playing with it and driving it around for a bit it loosened up a bit but not much or by any means close to normal... what could be the cause of this? Noticed a little bit of fluid build up under the transmission? Would a dry tranny cause this? Guy said it had been sitting for a bit.
I drove the car around and I could feel the all wheel drive system working pulling the inside wheel in (hard) turns. Also the steering seems heavy but there is very little play side to side. The suspension wise its seems good... new control arms, bushings, tie rods, etc. Not too much rust
Guy wants $1800 - What do you guys think? What else should I check for? I'm thinking as is maybe like $1000-$1200. Interior is ok shape as well.
I drove it and it feels solid... just the engine and shifter "woes" that are bumming me out. If these can be fixed for a reasonable amount or DIY I'm totally down... just don't want to be in it too much right off the bat
2nd,
3rd,
