Power windows stuck down in Florida with a hurricane approaching, help!
  • Namesake
    • Oct 2009
    • 27
    So i was driving with my windows down and when i went to park and roll them up, nothing. The right window has worked fine until this happened, the left window was slow to rise. A few days before it failed, it stopped working, but i was able to push the up switch and pull the window up. It worked fine for a few more days and now its stuck and has been for a couple days. What can I possibly do other than plastic bags, where would the fuse be?
    Gutted, welded, daily driver 88' 325is
  • dashboardmonkey
    FUCK YOUR WAFFLES
    • Jun 2008
    • 6158
    first, what year is your car?
    second, fuse box is under the hood
    third, use the god damn search button
    -Andy
    • ubernasty
      • Jan 2009
      • 2749
      Pull out all your interior and replace when storm passes.
      • Jean
        • 18228
        You can roll them up manually, remove the 'circle" cover where manual crank window handle would be and you'll see.
        • Schneider325
          • May 2004
          • 3818
          have you tried switching the buttons? If you find out you need a new motor/regulator and you have an early model E30, PM me.
          • deutschman
            • May 2008
            • 5958
            hurricane got down classed to a tropical storm so don't worry. ;)
            • ThaiRacer
              • 799
              yay hurricane drift here i come!!
              • Namesake
                • Oct 2009
                • 27
                I just went out to my car and I am not seeing any circles, or anything that could be popped off. The car is a 1988 325is, I've tried searching for the solution on the forum and cannot find. I really need to know how to manually crank the windows up, thanks!
                • e30nub
                  • Jun 2008
                  • 1741
                  Make sure the circuit breaker button is pressed down.
                  -Pierre
                  1987 535is
                  1988 325is
                  • ThaiRacer
                    • 799
                    There should be like a plastic circle tab on the door panels. Pop that out and stick in the right allen key and turn it.
                    • E30SPDFRK
                      • 5707
                      I would check this first
                      Some e30's don't have that. I forget which ones though.
                      Byron
                      Leichtbau
                      • VacMan
                        • Apr 2007
                        • 2405
                        Park it inside?
                        • ThaiRacer
                          • 799
                          I think 4 door sedans dont well that or the I series.
                          Because i have it and my friends 318i 4 door doesnt have it
                          • Wh33lhop
                            • 11705
                            I've got the little circular tabs, '87 325i 4 door. I was under the impression that late models didn't have em, but I guess I'm wrong too.
                            paint sucks
                            • accident
                              • 7303
                              my 88 325is has the pop outs for the emergency window crank, which is in your toolbox, assuming you have it. I think they stopped doing that in the 89+ models. personally i like it. if my battery dies or the window motors go out i can roll the windows up no matter what.
                              Moral of this story?
