Power windows stuck down in Florida with a hurricane approaching, help!
  • Erick
    Official R3V Drifter
    • 11169
    Originally posted by E30SPDFRK
    Some e30's don't have that. I forget which ones though.
    Correct-a-mundo. I thought it was an early/late model thing. I can tell you none of my 89-91 cars ever had it.
    But he says he has an '88 iS, and I just parted an '88 iS out, and the door cards have the crank handle covers.
    ..::Support FullOpp::..
    FullOpp Stickers for sale!
    Feedback Thread
    • recall
      • Apr 2009
      • 120
      I just picked up an 88is which doesn't have the crank covers. I believe it was built in early 88 (April). Maybe early 88's did, late didn't?
      • txtorquemade
        • 1758
        Originally posted by Jean
        You can roll them up manually, remove the 'circle" cover where manual crank window handle would be and you'll see.
        What he said....
        How bad is the storm supposed to be? Cat 2?
        sigpic 1987 325is
        • txtorquemade
          • 1758
          Originally posted by Namesake
          I just went out to my car and I am not seeing any circles, or anything that could be popped off. The car is a 1988 325is, I've tried searching for the solution on the forum and cannot find. I really need to know how to manually crank the windows up, thanks!
          ah crap.. sorry, I didnt read the whole thread.
          Pop the door card and do it manually.....or....
          Find a parking garage ....?
          sigpic 1987 325is
          • txtorquemade
            • 1758
            Originally posted by accident
            my 88 325is has the pop outs for the emergency window crank, which is in your toolbox, assuming you have it. I think they stopped doing that in the 89+ models. personally i like it. if my battery dies or the window motors go out i can roll the windows up no matter what.
            Now thats what I thought...(sorry to post whore).
            I think... (not sure cause my 90 is in the shop).. it is a early/late thing. If you have an 88, that must be the year, one would assume that differentiates early/late, and I think that is correct, isnt it?
            I know the 88 is sort of "in between" with the bumpers and other items. ie, the euro bumpers will fit PnP but not on a 87,which I suppose is the last of the "early" model.
            So ...yours aint got it huh? Well..like I said, pull the door card and a hex ought to crank it manually.
            Good luck...stay dry!!
            sigpic 1987 325is
            • Namesake
              • Oct 2009
              • 27
              I searched for door cards to no avail. Im trying to exhaust all my forum searching options before asking all of you for help. Im going to be doing this in the parking lot of my job, anyone wanna give me a quck run down how to pop the door card off?
              Gutted, welded, daily driver 88' 325is
              • E30SPDFRK
                • 5716
                push clips around the outside, 2 phillips heads under the arm rest and one behind the mirror adjuster switch. Slide the door handle surround rearward (I think its rearward, might be forward)
                Byron
                Leichtbau
                • Erick
                  • 11169
                  Yeah, it's definately not rocket science. It shouldn't take you more than 5 minutes to get the door card out. And it only requires a set of screwdrivers.
                  To make order of E30SPDFRK's post
                  1-) Slide the door handle trim sideways and pull it out (just slides out)
                  2-) Pop rear view mirror button with a flat head
                  3-) Undo all 3 screws holding the armrest in place
                  4-) Remove arm rest
                  5-) With a flat head, pop out all the clips of the door card from the actual door by prying near their location in between the door and the door card (about 6-8 total on the sides and bottom)
                  6-) Slide door card up and it comes out :)
                  Now the window you will need a hex key to turn it up, and you're set.
                  - Erick
                  Feedback Thread
                  • ben312
                    • Jan 2009
                    • 1139
                    Originally posted by txtorquemade
                    What he said....
                    [quote=txtorquemade;1747081]ah crap.. sorry, I didnt read the whole thread.
                    quote]
                    Originally posted by deutschman
                    hurricane got down classed to a tropical storm so don't worry. ;)
                    wow you really didn't read this.
                    Originally posted by Beej '86 325es
                    every time an M-tech 1 spoiler is destroyed, a baby seal dies.
                    Originally posted by Jparkr
                    The last thing we need are more of the retards on here thinking they are engineers too.
                    87 325:83 jetta coupe:99 volvo c70:99 volvo s70
