19 Pound Injectors in 86 Eta ***Need Help***
  • cobraken
    • Oct 2004
    • 674
    Hey, I installed 19 pound in jectors in my eta today and it wont even hardly run. Was this a bad Idea? Everyone said it was plug and play. I tried to drive it out of my neighborhood and it stalled out and then wouldnt restart.
    Advice? I am swapping plugs for now since mine are now all fouled out.
    Randall Racing and Engineering
    Acworth, Georgia, 30101
    http://www.facebook.com/RandallRacingandEngineering
  • ubernasty
    • Jan 2009
    • 2749
    When i put them in my eta it ran like shit too until i realized the oil dip stick came loose (don't ask me how). So check any vacuum lines... probably not the problem if it wouldn't start at all but tryin to help. GL
    • Mike325
      • Mar 2006
      • 3685
      Make sure all of the injectors are seated properly and that they are all actually working. How old are they? Did you replace any gaskets or o-rings for them?
      You may have a massive air leak.
      Originally posted by Kershaw
      • Jand3rson
        • 37587
        Who is everyone that said it was plug and play? From what I've been told, eta injectors are a much lower impedance than 325i injectors, I didn't think they would work.
        ubernasty, do you still have them in your eta? How does it run?
        • cobraken
          • Oct 2004
          • 674
          They were rebuilt injectors. They are all seated properly because there is no fuel leaks. We replaced all the o-rings. We even disconnected a very large vacuum line just to see if it changed, and it actually ran better but still barely ran. The car is clearly running super rich. All of the plugs fouled out within 10 minutes of running, it's dumping black smoke out the tailpipe, and the catalytic converter is glowing red.
          • E30Nova
            • 1546
            This. It's plug and play for "i" motors. Pretty sure they won't work on an "e" motor.
            Matt
            Matt
            I pack my CD player with asbestos. Those mother fuckers pay dearly for stealing my shit.
            Originally posted by kronus
            try whacking parts of the motor with a wrench while yelling "YOU WANT SUMMA DIS? HUH?"
            This is like a reverse build thread; it starts out nice and gets shitty.
            • lennon
              • Jun 2008
              • 1416
              what makes your eta need 19lb injectors and what ECU is controlling them? more info...
              • Jand3rson
                • 37587
                Matt
                This is what I've always been told. 325i injectors are high impedance, eta injectors are low. I'm pretty sure your car isn't going to run on them.
                What I've been told you CAN use are E28 M5 injectors, since they are the same low impedance type as stock eta injectors.
                • E30_fiend
                  • Apr 2006
                  • 7348
                  ETAs came with 18lb LOW IMPEDANCE injectors. 19lb injectors from like mustangs or even "rebuilt" ones from eBay are high impedance injectors.
                  Heres the problem, the injectors you bought are meant to be powered with higher voltage than the stock ETA ones. So case in point, you need to put the stock ones back in. ETAs arent race cars, they dont need to be suped up. Either get an i motor and to the swap or get a different car.
                  Taylor
                  • NeoMishMoo
                    • Jul 2009
                    • 448
                    Taylor
                    I agree with everything but this. ETAs are fun and can be suped up a bit, they have really nice torque, but 19lbs are not a good idea for an eta, Mark D won't even make a chip for 19lbs injectors. Put the old ones back in, but before you do get a rebuild kit and rebuild them! It will make them work so much better! I just rebuilt mine, was thinking about posting a guide.
                    West German BMWs, they just don't make the same as they did before the wall fell.
                    ^Case in point: Auto-Repair Technology. Everytime my car isn't starting or acting up I let it sit, sometimes for an hour, sometimes for days. But it eventually fixes itself.
                    • E30Nova
                      • 1546
                      ETA's came with 18lb injectors? Really?
                      I could have sworn all M20's came with 14-15lb injectors.
                      Matt
                      Matt
                      • Jand3rson
                        • 37587
                        You're full of crap. My eta motor is very "suped up", and it's fun as hell. I have a JimC chip with an i intake manifold and throttle body, and a ported head to match the manifold. My car hauls ass, and will hold it's own against a 325i just fine. I'm so sick of people being told that because they have an eta, they can't do anything with it.
                        • lennon
                          • Jun 2008
                          • 1416
                          eta cars just need a rearend swap and maybe chip/other little things to be as "fast" as stock b25 cars. its just not as fun revving to only 5k for some reason. the power stays in the 3-4k range. i parts and the 731 head fixes all problems, or porting the 200 head
                          edit- 666 posts!
                          • Jand3rson
                            • 37587
                            edit- 666 posts!
                            I don't even care that much that my car doesn't rev that high.
                            • cobraken
                              • Oct 2004
                              • 674
                              Well, put the old injectors back in the car and it runs fine... I have chunks of cat converter all over my driveway!!!! Im just glad to have my car running again. Thanks for all the inputs and advice.
