19 Pound Injectors in 86 Eta ***Need Help***
    • 34847
    the reason they don't work is because the opening time of high-z injectors is vastly different. you can physically drive high-z injectors with low-z hardware but it completely fucks the stock tune. On the other hand, putting low-z injectors into a car designed for high-z results in a fried computer.
    • daniel
      • 6703
      semi-related question to the experts:
      impedance set aside, can an ECU adjust itself to handle different injector flow rates at all? i guess it doesn't really have any way of knowing unless there was a return signal from the injectors back to the ECU.
      http://instagram.com/dslovn.drives
      • Need4Speed1299
        • Oct 2007
        • 119
        Injectors + chip
          • 34847
          there is limited feedback from the O2 sensor which it can use to trim back the injector pulse - to a point. But once you max out the injector trim that's all you get. you can't stick like 42# injectors in there and expect it to work, it's going to choke. aside from that narrowband sensors are really only accurate at 14.7:1, the further you get from that point the less effective closed loop EGO is at correcting your PW.
          • cobraken
            • Oct 2004
            • 674
            Well atleat I have injectors for the I engine sitting in the garrage. What a mess. Car runs great now with old injectors.
            Randall Racing and Engineering
            Acworth, Georgia, 30101
            http://www.facebook.com/RandallRacingandEngineering
