need quick help
  • der affe
    Technical
    • Dec 2005
    • 8452
    need quick help
    i just did an 95 M-3 rack swap and one of silence's P/S deletes. getting ready to do the toe.
    what do you set the toe at?
    zero?
    how much in ?
    how much out?
    it is a street car i drive fairly hard.
    thanks in advance
    Greg
  • der affe
    Technical
    • Dec 2005
    • 8452
    well i set it to dead zero toe, we'll see how it does.
    any one else set their own toe?
    • 2002maniac
      • 4260
      I like 1/16" toe in. Zero toe is good, but wanders a bit on the highway
      • der affe
        Technical
        • Dec 2005
        • 8452
        thanks, zero was a bit hard to steer too.
        • Nic01101011
          • Jan 2008
          • 1549
          i set my own toe last time, and went with 0 toe.
          what technique are you using?
          • der affe
            Technical
            • Dec 2005
            • 8452
            outside of center rib to same on other tyre. first measure front then back of tyre. figure out difference and adjust to acheive desired effect.
            i was going to make some quick toe plate but i ran out of time and light.
            taking it to my friends shop in a few days for an actual alignment on a rack anyways, but this should get me by.
            • z31maniac
              • 17566
              0 toe here as well.
              www.gutenparts.com
              • FredK
                • 14762
                0 toe, needles and string (this is r3v). No wandering or tramlining with 225mm tires.
                  • 34844
                  I went with 1/16in, $50 for a laser alignment can't be beat.
