The VS Bushing Thread. (give me some suggestions)
  • dr.gonzo
    • Nov 2009
    • 206
    So I was reading through the excellent urethane upgrade thread and need some suggestions.
    Heard bad things about AKG and squeaking so I counted them out.
    There are the IE Delrin which seem pretty good, stiff but good. Most of the roads around me are in excellent condition so vibrations aren't a huge concern.
    Powerflex comes next on my list. They seem good and well designed but I am not sure how stiff they would be. SO IE delrin Vs Powerflex? your thoughts..
    What about engine mounts and transmission mounts?
    www.roadreview.net
    • 34839
    I don't get the squeaking comments, I've had both AKG and IE and never had a single squeak. Plus the trailing arms rotate around the bolts, not the bushings. People must be doing something wrong.
    as far as delrin, it's going to be pretty harsh. I'd go with something in the 80a range, stiff but not completely solid. 70a is a little soft.
    • dr.gonzo
      • Nov 2009
      • 206
      So you would go with the powerflex?
      www.roadreview.net
      • SpyHunter
        • 318
        Is this a street car? Street and track car? Track car?
        I am going Powerflex on the subframe and trailing arms. Factory on the dif. But mine is a street car, that might see track time, but isn't planned. I want good control, without sacrificing comfort.
        In our track rat, we have delrin all around. The NVM is quite apparent. Not something I would recommend for a street car at all.
        • dr.gonzo
          • Nov 2009
          • 206
          Also Should I go with the offset bushings or symmetrical?
          www.roadreview.net
          • dr.gonzo
            • Nov 2009
            • 206
            It's a daily driver that sees daily canyons (my daily commute luckily enough) and will be seeing a fair amount of track time. It doesn't need to be terribly comfortable. I am in a Sparco Sprint V solidily mounted with a 5 point harness. Comfort isn't that huge
            www.roadreview.net
            • Mike325
              • Mar 2006
              • 3685
              I had powerflex for the rear subframe on my car and it was fine. Pretty solid but not too harsh. And I live in MA where the roads suck balls.
              Originally posted by Kershaw
              • dr.gonzo
                • Nov 2009
                • 206
                So Cab suggestions?
                www.roadreview.net
                • StereoInstaller1
                  GAS
                  • 22679
                  Offset is ONLY for high speed straight line stability.
                  AKGs rock ass. Zero squeaks, cheap, flawless fit, easy install.
                  Rear trailing arms though...well, have fun with that.
                  Closing SOON!
                  Thanks for 10 years of fun!
                  • dr.gonzo
                    • Nov 2009
                    • 206
                    so non offset for the cab? they looked pretty torn up (literally) but i am wondering if thats causing the poor alignment
                    www.roadreview.net
                    • allwheeldrive
                      • Jan 2008
                      • 272
                      If the CAB's are worn out, they'll play major havoc on the alignment. When i first got my car, the bushings were junk and the front tires which had just been replaced recently were destroyed.
                      • dr.gonzo
                        • Nov 2009
                        • 206
                        so what does generally everyone recomend AKG or powerflex?
                        www.roadreview.net
                        • gearheadE30
                          • Jun 2007
                          • 3734
                          AKG personally. All of the bushings on my car are AKG, and I have no squeaking.
                          Project M42 Turbo
                          • dr.gonzo
                            • Nov 2009
                            • 206
                            I did read bad things about akg quality but everyone i know speaks highly of them. Was it a thing with their older products or what?
                            www.roadreview.net
                            • ck_taft325is
                              • Sep 2007
                              • 6880
                              From what I've read, IE and AKG both have seen better and worse production periods of time. IE used to be the way to be. Now it's AKG and quite a few people have said not-so-positive things about IE's current line up.
                              Not to thread jack, but I thought the off-set M3 CAB's were a good replacement over the stock-centered non-solid version? Am I wrong? I'm in the market currently to replace mine. Opinions?
                              Need a part? PM me.
