I don't see the M5x and S5x ITB's on the site. Do they exist?
Coming soon to Guten ITB's...
The biggest change you're going to see is in responsiveness. After that would come flow at high RPM, but a lot of engineering has to go into intake runner lengths and plenums to avoid losing too much torque lower (think S50 vs. S52 vs. Schrick manifolds...). Let's see what is actually available :). I am not, however, sure that Emre's Option (B) would produce good (read: better than stock) results easily. There's a lot of testing involved and a fairly extensive knowledge of fluid dynamics. My hope is that the gentlemen at extrudabody will put their expertise to work to produce a complete set, at least mechanically.
Originally posted by CorvallisBMW View Postooooohhhh I just jizzed in my pants while imagining a euro hi-comp m30b35 with 533i flywheel and ITBs.....Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
Originally posted by fiftytakedowns View PostId much rather have the extrudabody setup, but dbilas has an itb setup that uses stock Afm, TPS, and is bolt on. That is quite appealing on its own.
that is my next step, ditch the MAF conversion with piggyback and go EMS of some sort. either MS or depending on cost extrude's EMS.
would like more info on their set up as far as cost, support, and plug and play or make your own harness.
if someone buys these, i can give them the dimensions of the airlog and runners if they need to make their own.seien Sie größer, als Sie erscheinen
oh and Dbilas does offer an intake mani ($950) for the M-30, BUT you will need to make your own airlog and fuel rail (custom). that kind of turned me off to that idea, if i did an M-30 swap, and i can do all that myself.seien Sie größer, als Sie erscheinen
Kevin and I have been working in conjunction to make his ITB's work for Forced induction and for BMW's for over a year now. I am also a dealer... as well as the fabricator/R&D guy. FWIW. The benefits have been overwhelming. One of the main reasons my car makes so much more power than any other typical setup like mine is a direct result of the airflow capability of the ITB's.
Mid range torque will be gained by the simple removal of the AFM. And torque will be lost from the reduction in length of the intake runners. Any dyno figures on the subject?Brake harder. Go faster. No shit.
massivebrakes.com
Originally posted by aproy View Postoh yea?!Brake harder. Go faster. No shit.
massivebrakes.com
Originally posted by vcsg1 View Postwould like to see something for the m42 as well...Originally posted by accidentI have achieved the title of Douche of the month.
Discuss.Originally posted by kronusIt was probably pissed off because it didn't want to pay taxes for poor people's healthcare.
1991 318i 4dr 5spd (DD)
I'd like to see M42 stuff as well.
I'm already researching a high RPM bored M42/M44 for the slicktop.Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
