Need help with alarm install ASAP
  • dr.gonzo
    • Nov 2009
    • 206
    Hey everyone I am trying to set my alarm up and i have read through all the threads and i am having a hard time figuring out which wires to tap into the trunk wires from the module, help?
    www.roadreview.net
  • e34john
    • Apr 2006
    • 3599
    did you look at the keyless entry sticky on the electronics section, theres a few wiring diagrams there.
    • george graves
      • 20003
      Installing under the dash is a much better choice. 99.9% of all alarm installs are done there. Is it too late to move it?
      Originally posted by Matt-B
      • dr.gonzo
        • Nov 2009
        • 206
        No i have been installing it under the dash, I have everything hooked in so he lights flash siren goes off, I even took the old alarm parts out above the stereo controls and put the new LED there and valet button there, I know you are supposed to splice the wires into the trunk so it trips the whole system but I am not sure which wires coming off the unit.
        www.roadreview.net
        • george graves
          • 20003
          The door lock module is located inside and below your driver side speaker cavity. Tap there. No need to run to the trunk.
          • dr.gonzo
            • Nov 2009
            • 206
            I thought I had to tap it into the wires coming from the trunk to unlock.
            www.roadreview.net
            • george graves
              • 20003
              IIRC both lock and unlock are right there in the driver's kick. What make and model?
              • reelizmpro
                • 9559
                Lock/unlock is right there behind the drivers front speaker at the central locking unit. Just tap right in.
                88 M3 - LACHSSILBER
                89 M3 - ALPINEWEISS II
                • dr.gonzo
                  • Nov 2009
                  • 206
                  just finished installing the door open sensor wires
                  www.roadreview.net
                  • StereoInstaller1
                    GAS
                    • 22679
                    OK, so what do you have left? Did you get the door lock figured out?
                    Closing SOON!
                    Thanks for 10 years of fun!
                    • dr.gonzo
                      • Nov 2009
                      • 206
                      I'm going back now for a test run of door lockes. should work hopefully. Will i need to to do any programming before it will work?
                      www.roadreview.net
                      • dr.gonzo
                        • Nov 2009
                        • 206
                        So I have this all together and I hear the alarm trying to switch over and its not working. I was connecting the wires together and i didnt have the green coming from the unlock side of the wiring harness. The green wire is going to the door which it says in the manual. Now i am thinking that green wire is supposed to go to the trunk wires instead of the green and black
                        www.roadreview.net
                        • dr.gonzo
                          • Nov 2009
                          • 206
                          I am about to scrap this whole project, this is not working out, CAN ANYONE HELP it driving me crazy. Would posting pictures help you guys out?
                          www.roadreview.net
                          • dashboardmonkey
                            FUCK YOUR WAFFLES
                            • Jun 2008
                            • 6158
                            did you use relays for the door locks?
                            www.the12volt.com is a great place for wiring diagrams
                            -Andy
                            • StereoInstaller1
                              GAS
                              • 22679
                              1. Nothing goes to the trunk wires...nothing.
                              2. You have yet to tell us WHAT FUCKING ALARM THIS IS!!!! What brand, what model.
                              3. You have not told us what wires you are connecting to in the car, or where you are attempting to make your connections.
                              Information please.
                              Luke
                              Closing SOON!
