Winter projects
  • b*saint
    • 3794
    Winter projects
    What are you winter projects?
    manual tranny swap
    fix shaky idle
    install new control arms and crb
    new front wheel bearings
    Ma che cazzo state dicendo? :|
  • JasonC
    Site Manager
    • 14451
    Change Corvair over from 3 speed to 4 speed.
    Put trans in my Dakota
    Put the 383 in my S-15
    1992 BMW 325iC
    1978 Chevrolet Monte Carlo
    • iamsam
      • Jun 2008
      • 172
      fixing up this bad boy:
      • TexasTerp
        • Jan 2009
        • 3541
        buy another e30, start collecting swap parts
        stephenbrody.com
        • gearheadE30
          • Jun 2007
          • 3734
          Install HID headlights (fogs are already in-they sent the wrong bulbs for the lows)
          Install rear headrests
          Sound deadening
          Find some way to get a bit more power out of my little M42...
          Project M42 Turbo
          • mrsleeve
            • Mar 2005
            • 16385
            Working all winter so no time to work on the E30 or even be at home.
            I will take the money as the last 2 winters I have spent way to much time off.
            Originally posted by Fusion
            William Pitt-
            • pureaudio
              • 1123
              Currently welding in new floorboards in my 2002, rebuilding the pedal box, and swapping out the 4th gear grinding 5 speed for a better condition one. Once that is done it is on to the E30. Pulling the motor to swap oil pans, remove A/C and replace the steering rack. I know I don't need to pull the motor for this but I want to do a very thourough cleaning on the motor and engine bay while I am at it. Oh, I am also installing plastic bumpers but since it is an 88, that won't take much time at all.
              Not to much on the list but since this is CA, winter should be over in about a month anyways.
              • ben312
                • Jan 2009
                • 1139
                get a new water pump in the e30
                get it running right
                new shocks, CVs and clutch in the jetta.
                maybe a swap in the jetta.
                Originally posted by Beej '86 325es
                every time an M-tech 1 spoiler is destroyed, a baby seal dies.
                Originally posted by Jparkr
                The last thing we need are more of the retards on here thinking they are engineers too.
                87 325:83 jetta coupe:99 volvo c70:99 volvo s70
                • dashboardmonkey
                  FUCK YOUR WAFFLES
                  • Jun 2008
                  • 6158
                  start aquiring car stereo gear for my E30
                  find another shell to replace the other E30(too much rust)
                  try not to shoot myself in the head in all that insanity
                  -Andy
                  • noE30
                    • Jun 2008
                    • 2260
                    replace gaskets
                    replace oil cooler
                    fix the sensors on my check panel
                    mini suspension rebuild (bushings/coilovers)
                    fix the misc issues with the body.
                    Flickr
                    @michael.colby on Instagram
                    "All he needed was a wheel in his hand and four on the road"
                    • thornado327i
                      • Oct 2006
                      • 501
                      Rear brakes - swap to discs (finally!)
                      Gas tank replacement
                      Rear shocks absorbers replacement
                      Some minor cosmetics
                      Summer wheels refreshing
                      New summer tyres
                      It's going to be tough given my constant lack of time...
                      • leland21
                        • 232
                        Finding a garage to rent/use since my dad moved to Florida...
                        As soon as that is sorted out, I won't be driving the e30 this winter so:
                        Pull engine to clean/replace worn parts/compression check and possibly head rebuild
                        Clean engine bay
                        remove suspension and clean/paint subframe
                        replace all bushings
                        possible diff swap
                        recover some interior pieces
                        get new to me rims stripped and repainted
                        replace brake booster (currently has a vacuum leak)
                        Re-hang exhaust and make new bracket to fit 5 speed swap
                        remove trunk tar
                        possible new Miller intake and chip
                        Plan what I'm going to do with it next. Everything is remotely inexpensive as long as I get a good deal on the suspension components. Just gonna try and get everything that is time intensive done while not driving it.:)
                        Actually just making this list is getting me all sorts of warm and fuzzy inside......
                        "We can't drink here.... This is frat country"
                        I'm gonna quote a lot of you later this year.
                        • Court M3
                          • Jan 2004
                          • 6713
                          Prep and install moonroof
                          Stereo install
                          Continuous For Sale Thread
                          323i s50
                          • bikerbill2021
                            • Mar 2008
                            • 933
                            i got myself an old 75 CB500T for 200 bux with an extra motor, gonna go the cafe racer route with it, and it'll be my back up ride in the summer
                            cant wait! :up:
                            • bimmer_E30
                              • 5001
                              Since i am in college and i need to study my ass off, nothing is happening....but in April there will be some work.
                              Do a full-tune up(timing belt, water pump), Repaint my front+rear appron, new tires, skidplate, fix the stupid electrical problems, get hids, tint the windows, re-do the the trims in black and finally fix the exhaust leak and give her a good power polish.
                              will probably be done in like july or somthing :(
                              Originally posted by e30e
