Winter projects
  • steeze
    • Aug 2009
    • 29
    hm where do I start.....
    -work more hours to pay rent, bills, and fund the e30 projects
    -try to keep on on homework (college)
    -purchase a garage heater of some sort
    -fix stupid electrical issue (misfire/stalling=annoying)
    -replace valve cover/spark plug well gaskets
    -chop a coil or two off my coilovers
    -start saving for new wheels in time for spring!!
    -fix water leak(sunroof drains?)
    -clean up engine bay
    that is all :)
    • 10Toes
      Me Father Was A Tree
      • Jan 2008
      • 61222
      -E30
      Fix heater
      New headlights
      Bigger Engine
      Clean up engine bay
      Rebuild Wheels
      New Tires
      IS side skirts
      Subframe bushings
      Trailing arm bushings
      Sway bars
      Subframe reinforcement
      I need to make a build thread.
      -E36
      LS1 swap
      -4Runner
      Weld on new inner fender
      Paint frame
      Reassemble
      -Clean garrage and sell extra parts
      -Find a new daily to replace the E46
      • z31maniac
        • 17566
        Euro trim, smoked turn signals
        is sideskirts
        get front and rear valances and front lip resprayed
        find houndstooth sport seats or just swap in my black leather sport seats
        rebuild a set BBS RS
        www.gutenparts.com
        • 325ix
          • Aug 2009
          • 7783
          Originally posted by iamcreepingdeath
          fixing up this bad boy:
          nice. when did you pick that up?
          • Stu
            • 4083
            Rebuild rear suspension/subframe, box trailing arms, new bushings
            Swap differential
            Install rear headrests
            Install new speakers
            Paint rockers
            De-cosmoline engine bay
            Remove tint
            Probably more..
            • alpn333
              • Dec 2009
              • 17
              Well I am about to complete my 318i to M3 conversion (full body, suspension, and drivetrain). It has been one heck of a process and now I just have to decide on if I am going to drop in the S14 unmolested or go full stand alone and turbo that sucker. Either way the EMS is where I am having issues. Do I go ATE, MS or something similar.I am leaning towards the MS. Here is a pic of her in its current state (body work will be done and the warsteiner decals will be applied)
              P.S. I have a ton of spare OEM pieces so if any of you are looking for OEM M stuff let me know. I am comming from the s14.net community.
              • evandael
                • Oct 2009
                • 2881
                Get the heater running, new HU/speaks, and suspension. Also little things like trim, lights, etc.
                Today I got the first one done! Nice n' toasty (its about 15 degrees out right now.. brrrr). And thanks the the PO, the new head unit is a bit more of a chore than it needs to be, but we'll see what I can't do tomorrow.
                Suspension wise, I'm waiting for my uncle to get his old Power Wagon off his full car lift. Damn nice garage he has... I'm sick of rolling around on the floor in mine!
                Then comes spring cleaning, new wheels and tires, and finally getting the thing plated/inspected/insured! It's a true project right now.
                • iamsam
                  • Jun 2008
                  • 173
                  Dec 9th to be exact. Super low miles, everything on that car works perfectly (except the AC i think)
                  • 2002maniac
                    • 4260
                    Finish prepping 928 for the track.
                    • Stu
                      • 4083
                      Secure the oil lines. I lost a track session due to a 928 dumping it's oil pan on the back straight at CMP ;)
                      • DaveSmed
                        • Apr 2007
                        • 1406
                        E30-
                        Everything.
                        Mercedes-
                        4spd swap, undo PO hackery, maybe install a decent radio.
                        Chevy-
                        Having rear brakes again would be nice. Also prob should look into new rear springs, U joints, and why the hell the steering is so sloppy. Definitely need to fix the water leak that is corroding the fusebox.
                        Cadillac-
                        Freshen engine, little bit of bodywork and a respray.
                        Everything I own is a piece of crap.
                        -Dave
                        2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
                        Need some help figuring out the ETM?
                        • Massive Lee
                          • Sep 2006
                          • 6785
                          Finish the M2 this winter. Kick some butt this summer.
                          massivebrakes.com
                          • Jand3rson
                            • 37587
                            Dye my carpet either black or dark grey
                            Possibly dye my headliner black
                            Get my MkII Recaro rear seat mounted
                            Possibly smoke my headlights
                            Change out my rear trailing arm and rear subframe bushings
                            • Unearth078
                              • May 2008
                              • 2623
                              freshen the s52 and throw it into the e30 after reinforcing the subframe and doing some rust repair.
                              Originally posted by Lof8
                              4 doors allow you to transport more whores.
                              therefore, their value is much greater.
                              Down to: 89 aw2 332i/4/5 , 70 Sahara 2002
                              • mrsleeve
                                • Mar 2005
                                • 16386
                                Originally posted by alpn333
                                Do I go ATE, MS or something similar.I am leaning towards the MS. .
                                Look to Wolf EMS much much better than AEM MS OR anyone else and make a plug and play for the e30
                                Originally posted by Fusion
                                William Pitt-
