Stupid things that PO's did to your car
  • keefy6
    • May 2011
    • 991
    #331
    ..Seems the good Dr. parked the car consistently directly under the sprinkler system. All my glass now is permanently watermarked.
    Ironically, I don't want to replace them. Even though I've modded my car a little, I'm still an 'original' (as much as I can) kind of guy. The VIN, etched on each piece glass, call me crazy.
    My old Style 5 Thread / My Swap
    1991 318IS :bow: 2.5L S14 Swap/BC Coilover suspension/Some new (old) wheels/
    IS Skirt-Lip/RG Splitter/M-Technic I Spoiler/Dogleg/3.46 Diff/Euro H4 headlights etc.
    1998 528I (Sold) // 2003 540I ///M Sport
    • Madhatter
      • Oct 2004
      • 966
      #332
      Attempted their own wiring. Full fucking stop!
      Ill post a pic tomorrow, but they cut circuits that didn't need to be cut, they bypassed the factory power window circuit for a shit alarm install, stripped wires then twisted them together and taped them over instead of soldering them, and instead of replacing the ignition switch, went to the trouble of wiring in a bypass button.
      Ohh, they needed power for the alarm under the dash so they cut the wiring going to the fog light switch and used it for power (who needs fogs?), then when they needed power for the control unit for the power windows, they cut the wires for the factory cigarette lighter and used those. Didn't even bother to splice into them, just snipped the spade terminals clean off.
      Just a little project im working on
      - http://www.lse30.com -
      • Freakshow
        • Apr 2013
        • 174
        #333
        Try claybaring the glass that should work. Some people will be against this but use steel wool and Windex if that does't work.
        • CrazyJew89
          • Oct 2009
          • 347
          #334
          I second this. Most people don't realize it, but you can polish glass, just like everything else
          '87 5-speed 325is
          The best $750 I ever spent!
          Are you in Michigan?
          Do you want to know where all the E30's are?
          Try checking out the Michigan E30 Map
          • G-Man
            • 479
            #335
            My former Euro spec 1970 E3 2800 was imported to So Cal in the early 70's before all the gray market rules came into effect so it still had speedo in KPH, no side markers or any federalization done to it. The PO of the 2800 removed the Euro 5.75 H4 with city lights and replaced them with sealed beams, go figure. The H1 high beams were still there when I bought the car in 2004. I took some searching but I found some H4 with Euro city lights for the E3.
            G-Man
            74 2002tii (many mods)
            86 325 (sold)
            88 325is (sold)
            89 325i (totaled)
            91 318is (parted out)
            91 318i
            98 Tacoma Prerunner (parts hauler)
            • Madhatter
              • Oct 2004
              • 966
              #336
              From this mess of bullshit wiring.
              Back to the few factory plugs and relative neatness.
              • AdamPlaysDrums
                • Apr 2012
                • 140
                #337
                My car had an allegedly "rebuilt" m42 in it, which at first seem fantastic. Now, though, I've discovered VR gaskets used, aftermarket parts that are constantly breaking (block coolant pipe and fuel pump did so rather catastrophically), three different brands of belts, power steering belt tensioner installed backwards, alternator belt tensioner destroyed...and it appears the head gasket was made with RTV sealer. May be doing this one over.
                • QUKBMER
                  • 8178
                  #338
                  PO had a shopping cart wing on the trunk lid,it was gone when i bought it but the holes were still there.He also painted ONLY the intake manifold fluorescent bright orange WTF ? It was not the white e30 in my sig pic thank god !!!
                  • mrmckie
                    • 728
                    #339
                    autolite spark plugs.....:tsk:
                    "I came into this world, not chiefly to make this a good place to live in, but to live in it, be it good or bad" -Henry Thoreau-
                    1991 318is - the cruiser
                    1989 325i - the rats nest
                    • henryki
                      • Jun 2013
                      • 960
                      #340
                      Managed to get rust on the drop hat to form on the shock? so gotta replace the whole strut, then heated all 4 springs.. -_-
                      Also when I bought the car he had me waiting with no response for 5 hours, the only reason I hung around the area was because I drove about 2 hours to see this thing and I wasn't about to just go home without seeing an e30. ended up shooting his price down from 3,900 to 2,000 but first thoroughly insulted him with an offer of 1,000. Ended up being so pissed off with the deal because it didn't pass smog like he said it would. SO craigslist personals men for men mustve had a field day. Also so did 4chan. All i gotta say is fuck that guy.
                      • Freakshow
                        • Apr 2013
                        • 174
                        #341
                        Dumb previous owner welded them on i guess the belt broke before and bent some valves.
                        They were too lazy to replace the head and did a temp/cheap fix.
                        I know its not smart to keep driving like this, will the other ones break soon as well?
                        • TurboJake
                          • 3780
                          #342
                          Nope. As long as it isn't consuming oil, which I doubt it is. Run it. Worst case scenario at this point really is leaking after however many heat cycles since. Head might crack, but doubtful. Or more might chip off and you fuck up the head some more.
                          Heads already fucked, so anything after this is the same outcome. New head.
                          Leave Me Transaction Feedback
                          • Freakshow
                            • Apr 2013
                            • 174
                            #343
                            Thanks for the help. Going to get a rebuilt head from CA tuned.
                            • 88e30is
                              • Feb 2007
                              • 690
                              #344
                              Not really stupid but, my whole car smells like gas inside because when he changed the fuel pump he either didn't seal it or there is a hose loose.
                              • tifosichris
                                • May 2008
                                • 216
                                #345
                                Cup holder drilled into my e30s perfect and crack free dash. Took it out immediately but the holes are still there. Makes me cry inside
                                Auto Technic J-Stock Suspension Kit, Bilstein Shocks and Struts, ST Sway Bars, Front Camber Plates, Offset Euro Upper Strut Mounts, Chassis Reinforced, Aluminum Rear Shock Mounts, Offset control Arm bushings, Custom Control Arms, Custom Springs, Conforti Chip, UUC Ultimate Shift Kit, Kosei K1s, Sabelt 5 Point Race Belts
