Insane BMW drift video
  • Jand3rson
    • 37587
    A really good video, with tons of BMW oversteer fun! Lots of E30 action too, and a little something at the end for you motorcycle guys. The guys in the M-Roadster and the yellow E36 M3 are quite good.
    RIGHT CLICK, SAVE TARGET AS:
    Live Draw HK adalah situs Live Draw HK tercepat, resmi dan terpercaya se-Indonesia. Situs ini Sah dan Resmi untuk para togellovers untuk melihat Live Draw HK Malam Ini, Data Keluaran HK, Result HK dan Keluaran angka togel hongkong wla yang keluar dari TOP HK 4D
  • diegom6
    • 4447
    Re: Insane BMW drift video
    http://www.mobisux.com/tabla/files/M...0Part%20II.wmv
    is the smae one that just someone posted in e30tech and weight a bout 111MB?
    Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
    • Jand3rson
      • 37587
      Yeah, I thought everyone here would like to see it, too.
      Diego is right, I forgot to add, it is a 111 MB download, but well worth it. :up:
      • e9nine
        • 1890
        ..it is a 111 MB download, but well worth it. :up:
        Agreed
        • PeaveyBassist
          • Sep 2004
          • 3511
          Agreed
          Agreed x 2 ;) Way cool vid.
          Will
          RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
          Welcome e30 (brilliantrot '90 325is) 12/23/06
          DaveCN = Old Man
          My signature picture was taken by ME! Not by anyone else!
          If people keep quoting me in their sig, I'm going to burn this motherfucker down.
          • bmwm3n528
            • 3654
            Got all blurry on me...the dude in the Dakar M3 can straight up drive.
            Trevor Ely
            '95 M Sport 540i - '00 A4 1.8TQMS - '85 190E 2.3-16
            '88 535is - '87 325e - '89 325is - '91 318is - '90 325is - '96 328is
            • 808BMW
              • 2910
              Sick video. Anyone know a prog to comvert from wmv (avi would be nice too) to mpg?
              Yes I know the quality will suck, I just want it portable so I can play it on my DVD player.
              • Jon325i
                • 6934
                ....and that wins this weeks' "kick ass" award :up:
                Jon
                Rides...
                1991 325i - sold :(
                2004 2WD Frontier King Cab
                RIP #17 Jules Bianchi
                • M42Technik
                  • 9781
                  That one E30 is quite the beater.
                  Reminiscing...
                  • bmwannabe
                    • 900
                    downloading....
                    59:00 mins left.
                    maybe DSL is my limiting factor
                    512 ram 80GB Hard drive and 3.0 GHz
                    • DEV0 E30
                      • Oct 2004
                      • 8879
                      Originally posted by bmwannabe
                      downloading....
                      59:00 mins left.
                      The server isn't that quick, must have a limit speed, and my wireless card kills my dl speeds.
                      • Il Duce
                        Non-Mod M42 Modder
                        • 5030
                        took me a very long time to DL, good video, god i love M coupes....
                        DORITO!!!!!1
                        • bmwannabe
                          • 900
                          well, that movie was kickass. The M coupe is my fave BMW of all time. That e30 was quite the track sliut, how do you induce the kinda drifting they were doing? Also anyone got an idea what country that was shot in?
                          • e30 gangsta
                            • 3877
                            That has to be the best bmw drifting video ever!!!! Man nice find. Keep em coming!!!!
                            • e30 gangsta
                              • 3877
                              Tthey probably used weight shifting/ braking drift... you see his lights come on then the back flys out... for more info read on...
                              Braking Drift how-to (and why it works)
                              For a braking drift you're essentially keeping the front tires on the hairy edge of their traction limit and making the rears exceed theirs. The braking drift can be a very fast way to slide out a car that has initial oversteer on turn-in and understeer on sustained cornering. Setting up a car this way is easily done by reducing the effect of the frontal sway bar and lowering the dampening effect of the front shocks.
                              The technique is rather simple - you don't brake and turn at the same time, but rather brake hard, release, and while the weight is still at the front of the car you give steering input. Because of the physics of tire load and the characteristics of rubber, a tire is capable of doing more work when it is under a vertical load than if there is no load. This can be illustrated by trying to push a rubber eraser across a table. When the eraser has only its own weight as vertical load, it is quite easy to push around. However, if you were to push down on it with a finger and try to move it across the table it “pushes back” with a lot more force. This phenomenon would suggest that you can make a car handle better just by adding more weight, but this couldn’t be farther from the truth… When a car goes around a turn, the tire is asked to support the vertical load but also to support a lateral load as well. The relationship between added weight and a tire’s added lateral work capability is less than 1:1 – by adding more weight you are asking the tire to support more turning force than you are benefiting it. If it were possible to increase vertical load without increasing the lateral load, then it would be possible to reap the benefits of a tire’s increased capability to perform lateral work without having more weight to do lateral work for. This principle is the basis for how downforce increases grip - increasing the vertical load without increasing weight (lateral load) results in an increase in tire the traction capabilities (“lateral work”, often represented in the Traction Circle).
                              At the front:
                              Under braking, the vertical load on the front tires has increased, making it possible for the rubber to do more work, but the amount of weight that they are asked to redirect has not changed because the car still weighs the same. The work being done by the tire will be at the edge of the traction circle under heavy braking as it is, so if you kept braking and gave steering input you'd make the tire's load exceed the available traction. However, if you quickly release the braking force and quickly give steering input you might be able to utilize the temporarily enlarged traction circle (thanks to increased vertical load and therefore increased capacity for work) before the re-balancing of the weight causes the circle to return to normal size.
                              In short - if you try to brake and steer at the same time, the car will understeer due to frontal washout. If you brake and steer in quick succession, you will have increased load capacity and the car will turn in hard.
                              To the rear:
                              Now, with a lower vertical load (due to weight transfer forward) and the same lateral load on the rear tires the traction circle has, in effect, gotten smaller. It won't take much at this point to let the break traction back here. If the car is setup to do so, the rear may even break away on its own since you will still have a bit of braking force being asked of the tire in it's small traction circle (especially if there is excessive negative camber resulting in less contact patch before body roll takes effect). If the tires don't break away this easily you are then left with the options of E-brake, power-over, throttle-off, shift-lock or clutch kick to generate a higher load than the work is capable of doing.
                              Each technique will operate differently to move the work required of the tires to outside the boundaries of the temporarily smaller traction circle. E-brake, throttle-off, and shift-lock will serve to break traction by slowing the tire down while the power-over and clutch kick speed the rear wheels up (depending on how the kick is executed). Your best bet is to use a declarative method rather than an accelerative method, since by virtue of being a “Braking” drift (braking is the key word here, in case you can’t tell) the rears are being slowed already. At this point there should be a lateral load on both the front and rear tires (car is now post-turn in) with the fronts gripping and the rears sliding slightly. If you are too quick to apply power in the braking drift, you may cause the tire’s location on the traction circle to move the across the vertical axis and back into the center of the circle where it may grip again (also accelerating before the car is sideways will transfer more vertical load to the rear and give the rear tires more traction, causing understeer). You have to make sure that the car is effectively sideways before applying more power. When the rear tires have broken traction, the car is in the early stages of a braking drift.
                              From here, the line through the turn that the front wheels will take needs to be smaller in radius than that of the rear wheels, essentially meaning that the rear will have to be traveling slightly faster than the front. Controlling the angle of attack will be a matter of simply putting on the power and modulating the throttle so that the rear line is faster, but not so fast that it incites a spin. Power application should be done quickly but smoothly – too big of a sudden jolt of power and the tires will completely loose all grip and the car will spin, too slow and the rear may regain grip and you’ll loose the drift. The faster the rear goes the larger angle, and the slower they go the shallower the angle. The ability to control the front and rear end speeds is one aspect that gives a RWD-only car an advantage over a FWD (where the rears can only be slowed) and many AWDs (where the average driver cannot control the front and rear axles separately without special modifications).
                              I hope this helps clear things up - if not, you may want to consult a book like "going faster" or "high performance handling handbook".
                              -MR
