Intake manifold removal...FML
  • dannyg
    • Mar 2007
    • 1553
    This thing is ready to come out, just stuck with a wire that goes to the fuel rail...any ideas how to take this off?
    1993 325ic Schwarz/Natur
    1991 318is Black/Black - Slicktop - Project s52
    1989 Alpine White/Black M3 S52
    1988 Henna/Pearl M3 <3
  • Wh33lhop
    • 11705
    We're looking at an M42 here, are we not? The M20 doesn't have a harness rail like that.
    Either open up the harness rail or find out where the wire goes...
    paint sucks
    • Farbin Kaiber
      Lil' Puppet
      • 29502
      DC the rail harness from the injectors?
      • dannyg
        • Mar 2007
        • 1553
        The engine is an M20...
        • ansonivan
          • Jun 2008
          • 224
          The M20 has a large round connector approximately under the throttle body which can be disconnected, is this a second set of wires or the main wire set?
          https://www.facebook.com/pages/Durocco/148629038574264
          • bmwguru007
            • 561
            Definitely an M20. The later models have a plastic injector harness rail like that. OP that wire leads to a multipin connector under the manifold. The bottom part of the connector unscrews a half turn or so and then there is a plastic ring that holds the injector harness connector to the support. Just unscrew the ring and it should pull right out.
            • shiboujin
              • Feb 2006
              • 2791
                • 37832
                You were able to unbolt the intake manifold and everything related to it but you couldn't figure out how to trace the wires to a plug?
                Classic BMW Specialists
                Grover Beach, CA
                www.BimmerHeads.com
                • dannyg
                  • Mar 2007
                  • 1553
                  I traced it to the plug, which is exactly what bmwguru said. The bottom part unscrews, but the top half is in a bracket, its hard to get a pic of it. I don't want to just yank it out, so I'd thought I would check here first...
                  • bmwguru007
                    • 561
                    There is a thin plastic ring on the underside that holds that side of the plug to the bracket. Unscrew it and the plug will come out.
                    • dannyg
                      • Mar 2007
                      • 1553
                      Thank you sir! I'll let you know how it goes tomorrow...
                      • shiboujin
                        • Feb 2006
                        • 2791
                        There is a thin plastic ring on the underside that holds that side of the plug to my asshole. Unscrew it and the plug will come out.
                        Fixed
                        • dannyg
                          • Mar 2007
                          • 1553
                          Finally got that bastard loose...Tomorrow on with the new!
                          • tjmonsen5
                            • Jan 2006
                            • 232
                            hmm thats cool, i didnt know the later M20s had a fuel rail with an integrated injector harness in it!
                            • Jean
                              • 18228
                              Hope you'll take advantage of doing this and replace all the old gaskets/hoses while you are there if they haven't been replaced already ;)
