GC Adjusters stuck on trailing arms!
  • z31maniac
    • 17566
    Guys, I sold my coilovers to a member here and getting everything else off the car hasn't been a problem.
    I'm having a serious time getting these off the trailing arms, obviously, I'm trying to make sure I don't gouge/damage them etc.
    Any ideas?
    www.gutenparts.com
  • gearheadE30
    • Jun 2007
    • 3734
    Tons of PB Blaster? You could also try using a torch to heat up the sleeves, but I'm not sure how much heat the andodization can take.
    Project M42 Turbo
    • z31maniac
      • 17566
      I'll pick up some PB blaster on the way home. Granted I haven't gotten to forceful with them yet either.
      www.gutenparts.com
      • FredK
        • 14760
        The anodization should be able to take the heat fine. Aluminum, on the other hand, cannot take that much heat without affecting its mechanical properties. Torching something is an inexact process and I would not recommend it on aluminum. I would use PB Blaster and a rubber mallet or soft wood and a hammer to promote penetration. Time and cursing are the other two requried elements.
        • sharky
          • Jan 2005
          • 2672
          BFH and a prybar working it around.
          • Erick
            Official R3V Drifter
            • 11169
            Ah yes. Priceless comment that happens far too often and seldomly noted. :D
            But yes, rubber mallet should do the trick. It sounds like it would work better than my idea, which would be to pry it off the collar with a rag wrapped in a prybar.
            - Erick
            ..::Support FullOpp::..
            FullOpp Stickers for sale!
            Feedback Thread
            • dannyg
              • Mar 2007
              • 1553
              I'd give it a few whacks with a rubber mallet...
              1993 325ic Schwarz/Natur
              1991 318is Black/Black - Slicktop - Project s52
              1989 Alpine White/Black M3 S52
              1988 Henna/Pearl M3 <3
                • 34839
                yeah, rubber hammer. I usually take mine off to clean them once a year and make sure no shit/rust is stuck in there. they get stuck.
                • StereoInstaller1
                  GAS
                  • 22679
                  Anti-seize next time?
                  -real helpful, huh?
                  Closing SOON!
                  Thanks for 10 years of fun!
                    • 34839
                    that won't stop rocks/grime from getting worked in there. that's why they get stuck.
                    • Farbin Kaiber
                      Lil' Puppet
                      • 29502
                      Everybody said rubber mallet, but I bet you could do it much easier and safer with a 5+lb. deadblow hammer. It is my suggested method for beating on a car, and they are cheap as dirt at harbor freight. I have a bunch I have beat the piss out of, and had only one of them explode on rusty rotors and such.
                      • BigD
                        • Jul 2006
                        • 1085
                          • 34839
                          that's true, rubber mallets generally suck for working on cars, but I wouldn't want to damage the threads. maybe use a block of wood to hit on it with.
                          • Farbin Kaiber
                            Lil' Puppet
                            • 29502
                            ^ They are made of soft plastic and filled with lead shot. You can beat on a threaded stud and not damage it.
                              • 34839
                              yeah, I've got a few - that's the problem really, they don't give you a really sharp blow like you need. you can beat on your control arm ball joints with a dead blow hammer all day and it won't pop free. but 2 sharp wacks with a 5lb metal hammer and it falls right out..
