I'm starting to have a weird cooling issue. It is even stranger due the fact that is seems to be getting worse the colder it gets outside.
My needle use to stay right at the 1/4 hash mark, but now whenever I'm idling the needle starts to creep up. Today I was in a really long lunch line at a drive through, and I even got into the red. Thankfully I saw it and turned the heater full blast. That seemed to help a bit, but my heater has been a little weak lately so it didn't do much. I was able to get the needle back to straight up by revving the engine up to about 1500rpm for a couple secs. I'm thinking it kicked on the fan or something? Any way, I had to do that a couple times, but everything was fine after I started driving again.
Also might be related, but my coolant is low, at dead cold it is barely visible in the expansion tank. This is another weird thing, as I have tried to refill the coolant up to the correct level a couple times and every time after driving for a while it goes right down to where it was. I finally gave up as I could still see coolant and I have no leaks, so I figured it was relieving pressure or something and ejected too much coolant. I hadn't had any cooling problems until this point, so I didn't bother figuring out what was causing it.
So, my guesses as to what I need to do to fix this:
Am I on the right track? First car, so I'm a total
What else do I need to look out for. Any other tips or tricks appreciated
- Test fan clutch
- Take a look at the heater core and see if that is blocked or something
- Look at the thermostat and confirm it is working correctly
- Make sure my expansion tank is not leaking
- New coolant and bleed system (bought the car in the summer and the PO said that the coolant was kinda old)
