should i buy these rims
  • KillaCam
    • 2103
    they are 4x114.5 for accord and nissan but they are only 250 bux
    i know its small but thats all there was
    here is another should I buy they are for 35 bux no rails and they are tenzo r's this one has minor rips but the other is missing a whole bunch of fabric
    Let me know
    Originally posted by E30_(1st Musk)_
    HONDA IS WHERE EVERY TREND DIES! .
    24v swap Oil Pan..F/S
  • KillaCam
    • 2103
    they are lagit borbet type a
      • 37829
      Call and get estimates to have them welded and redrilled.
      That should help you decide.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • HarryPotter
        • Jan 2010
        • 3642
        That's up to you I would say. If you have some type of use for them go for it.
        John F. Kennedy
        • KillaCam
          • 2103
          well i was thinking of getting adapters for it
          • Strelok
            • Jan 2010
            • 280
            I've heard nothing but bad about adapters. Don't half ass it.
            • widebodye30
              • Jan 2006
              • 3407
              For another $450.00 you can buy a brand new set of esm 009 borbet reps in 16x7.5 and 16x9 BRAND NEW no adapters or drilling and filling needed:)
              www.esmwheels.com
              www.dtmfiberwerkz.com
              Toll Free: 800.729.5450
              Local: 818.341.9903
              • accident
                • 7303
                fuck you and your shitty knockoff wheels.
                Cam: adapters are kinda wack. Stephen is running them and his wheels poke out way too far. For $250 getting them filled and drilled would probably be way worth it for legit borbets.
                Moral of this story?
                  • 37829
                  This is completely unnecessary.
                  Have you had first hand experience with his products? No.
                  Grover Beach, CA
                  www.BimmerHeads.com
                  • Danny
                    • 14216
                    Get them and then get them redrilled?
                    • White325is
                      • Oct 2006
                      • 5947
                      They are FWD rims so the ETs are more then likely way off for just a drill and mounts. So he would need a spacer for sure.
                      But your saying a 25mm adapter is worse then a 25mm spacer?
                      VW crew have been rolling on spacers for years and years now. I dont think I have ever read any where once of someone having a serious issue with them unless installed wrong.
                      • newman
                        • Mar 2007
                        • 1159
                        Spacers and adapters are 2 different animals, really... It'd probably be easier to redrill your hubs and get a hubcentric spacer.
                        1987 325is: 495whp/400ft-lb
                        UPDATED 03/12/10!: RB26DETT Swapped E30
                        • decay
                          • 5637
                          4x114.3 will not need to be welded, just redrilled with a set of 4x100 holes. you can get multi-lug wheels with both patterns.
                          whether to get them depends heavily on what the offset is, IMO.
                          past:
                          1989 325is (learner shitbox)
                          1986 325e (turbo dorito)
                          1991 318ic (5-lug ITB)
                          1985 323i baur
                          current:
                          • Stephen
                            Шлем ишака
                            • 10774
                            Whats the specs? and my wheels do not sit out too far.
                            My guess is they are the exact same specs as mine, and ive already dealt with that headache
                            • widebodye30
                              • Jan 2006
                              • 3407
                              ::crazy::crazy::crazy:
                              Thanks Matt!
                              Either way Im just trying to help.... for a couple hundred extra you can get a wheel that will be a DIRECT fit for your car and they will be brand new with 4" polished lips on the back and 3" on the fronts with the right offsets for the e30.
                              For the few hundred extra personally I think the best thing to do is to get ones that are ready to go because in the end you will end up spending almost as much to make em fit RIGHT.
                              Thanks,
                              www.esmwheels.com
                              Local: 818.341.9903
