modifying the steering knuckle
  • 87-325ic
    • Apr 2006
    • 1198
    Well, the knuckle is out and the rivets are mostly ground through..
    And now im trying to seperate it.. ill grind away at the rivets some more before i ask how much those need..
    but since the pics are down for the e36 rack swap thread, i need someone to show or explain to me where i need to grind at the u-joint to make more turning clearance, is it both ujoints? or just one?
    any help would be appreciated..
  • Gnarles
    • Dec 2008
    • 342
    once you grind down the rivets enough, the knuckle should separate with a little effort.
    I waited until I got the steering rack and knuckle back in the car and everything hooked up, then I spun the steering wheel back and forth and found where I had clearance problems and ground down just enough to clear.
    • 87-325ic
      • Apr 2006
      • 1198
      thanks.
      pics are back up too
      , and the rack is in!
      ill post all my fun in the big thread for others to have a good idea what to expect.
