STUPID? all e30 front struts the same
  • richardkeith97
    • 1693
    i thow the ix is different but i got some billy sports from my 85eta. will they fit my 90is? thanks
  • Fidhle007
    I can fly, motherfucker
    • Oct 2005
    • 7209
    There's a diameter difference between early and late cars but I don't know what the cutoff was. I'm sure someone will chime in with it though!
    '89 325is S50 Track Montser
    '04 X5 Daily/Tow Vehicle
    http://www.avarestoration.com
    http://www.myspace.com/brendanfiddle
    Click here if you want to be my zombie slave...
    http://www.youtube.com/user/Fidhle007
    • Joe318is
      • Sep 2005
      • 6451
      84 - 85 318i have different strut diameter [47 vs 51mm IIRC]
      M3's have a different knuckle. Otherwise they are the same
      Originally posted by vlad
      • Fidhle007
        • Oct 2005
        • 7209
        ^ There you go.
        • FredK
          • 14763
          45mm vs. 51mm
          I believe the switchover happened for production date >3/85 318i
          • Naplm00
            • Nov 2008
            • 1573
            and you can always switch the strus housings to accomodate the larger struts onthe 318 correct?
            I always wondered this
            88 325ic ~~~> Rusty and ugly
            85 E ~~~> RIP
            • Rigmaster
              • 3464
              Early 325e's also have the smaller struts.
              Yeah, if you install the larger strut housings on an early car, you can use the larger strut inserts. (if that's what you're asking)........
              • richardkeith97
                • 1693
                so that would be a no. i cannot install my 85 struts in my 90 e30 unless i change the strut housing also. then i'd hafta delete the abs since have abs hole in the 90 and not in the 85?.
                • Jean
                  • 18228
                  Just find a set of correct housings, junk the m10 stuff lol.
                  • richardkeith97
                    • 1693
                    so i need an 85 strut housing with abs to use these shocks? or i can delete the abs? this is a pain in the ass lol
                    • DRTSRFR
                      • May 2008
                      • 1836
                      Early housings have no provisions for ABS...
                      Suspension tips here...
                      http://www.r3vlimited.com/board/album.php?albumid=757
                      • richardkeith97
                        • 1693
                        so i hafta delete my abs. blah. billy sport shocks for sale. used for 1 winter. 4000 miles on them at the most.
                        • Will_318i
                          • Jan 2010
                          • 482
                          ^ PM'd
                          "get in, get off, wipe your dick off on her sheets and get out."
                          • M-technik-3
                            • 18946
                            What strut cartridges do you have? Model number so this silly question doesn't get all convoluted.
                            Never mind what you need is the strut collar that holds a 45mm strut in a 51mm strut. Bilstein sells this sized gland nut.
                            • richardkeith97
                              • 1693
                              so this is possibe to do. i just need a different gland nut?
