a stupid question.. have a quick answer?
  • 87-325ic
    • Apr 2006
    • 1198
    I know this is a very dumb question, but how do i use the "anti-squeal" grease/ lube/ whatever it is???
    I never used it when i replaced the pads and rotors, but now they squeal when coming to a stop... and its getting annoying.
    do i just squirt a small amount on each side of each rotor or what?
    Thanks. and sorry for being a tard.
  • lennon
    • Jun 2008
    • 1416
    the stuff youre talking about goes on the back of the pads, not on the friction surface.
    • 87-325ic
      • Apr 2006
      • 1198
      what makes my shit stop sounding like i need to replace my pads?
      • 87-325ic
        • Apr 2006
        • 1198
        oem pagid pads and brembo blanks
        • braytonia
          • Dec 2009
          • 216
          Did you break in your pads?
          • FredK
            • 14762
            backs of pads and the sliding surfaces on the caliper--on the carrier, the machined surfaces that the caliper touches.
            • braytonia
              • Dec 2009
              • 216
              http://www.zeckhausen.com/bedding_in_brakes.htm
              If you don't break them in they tend to squeak...
              • 87-325ic
                • Apr 2006
                • 1198
                sweet thanks. i never officially did anything to bed them.
                • Mossman
                  • Apr 2006
                  • 1961
                  roast those suckers before you bother with the anti squeal. When your wheels are on fire carefully release the brake and drive for 2 minutes without slowing down for anyone.
                  • willybustaE30
                    • Apr 2006
                    • 143
                    if there not smokin, there not broke in.
                    • braytonia
                      • Dec 2009
                      • 216
                      I aggree!
                      • HarryPotter
                        • Jan 2010
                        • 3642
                        Not really sure where I could go 60 mph to 10 mph using hard braking 8 fucking times without getting pulled over by a cop. :crazy:
                        John F. Kennedy
                        • 87-325ic
                          • Apr 2006
                          • 1198
                          yeah, it sounds like fun... i may have to wait until the roads dry up some and the traffic is non existent. (early morning)
                          • Atreus
                            • 1846
                            yeah dude you definitely gotta heat those up first to bed them, it worked for me
                            1991 325iC - Mauritsblau sumthin metallic blue. DEAD
                            1992 525i - Silber sumthin sumthin metallic- Rolling again, needs suspension/wheels/brakes/paint.... Fuck you A4S310R; BEAT YOU.
                            1989 325i - Cirrusblau Metallic sumthin sumthin-project - trying to clean up the interior(done), then the body, then a 5spd, then suspension, then..... - [Stolen :| ]
                            1991 325iC - Calypsorot Metallic
                            1994 540i - Granitsilber
                            Originally posted by scabzzzz
                            I've had blunts cock in my mouth, but I'm not gay.
                            • Kershaw
                              • 11822
                              use small abandoned roads. you can hit the gas to get to 60 and then hit the brakes all within a matter of seconds.
                              bedding in the brakes is very important and you can do it any time. if you have driven 10k miles without doing it, you can still do it. and if you notice the blue coating of brake pad material wearing off the rotor, you can rebed your pads. normal driving will remove it over time and heaving driving will sustain it.
                              AWD > RWD
