Check light question...
  • 88SuperETABD
    • Apr 2009
    • 911
    Is there a way to open up these checklights? I wanna take out the bulb or somehow make it so my check light doesnt come on for my windshield washer fluid...considering i TOOK it out..i know theres no in it...dont need that idiot light. Another thing is my break lights are working just fine...all of them...but for some reason my brake light idiot light comes on randomly....i do have a 2000w 12" sub...could it just be shorting or something...when the light comes on i have NEVER seen that my brakes arent working. And ive made sure all bulbs and everything is snugly in.
    (SOLD) 1988 327i Build Thread: http://www.r3vlimited.com/board/showthread.php?t=155086
    1970 Gruppe 2 2902 M20 Turbo Build: http://www.r3vlimited.com/board/showthread.php?t=373891
  • BigTe30
    • 207
    is it the brake pad wear indicator light? or the "brake light" light up top? because if it is the former then it is most likely the sensor (on the caliper), i just replaced mine and it flickers all the time. The new sensor just does not fit in tight enough
    • foofopps
      • Sep 2009
      • 529
      sounds like he is talking about the check panel. I'd also love to be able to deactivate some parts of the check panel like the brake lights because Im not going to spend my time chasing that fix when my brake lights work just fine. and yes i used bmw bulbs and cleaned the bulb connections.
      Originally posted by b3albakii
      the head was okey .. and in a good mood
      no i didnt over heat it so much
      www.blunttech.com
      • u3b3rg33k
        • Jan 2010
        • 2452
        I think you may be developing chassis / harness ground point issues. Also, just short out your washer level sender if you want it to be off.
        I think you should fix your shit, instead of defeating the "hey driver, your shit's broke" system.
        Ich gehöre nicht zur Baader-Meinhof Gruppe
        Originally posted by Top Gear
        Just imagine waking up and remembering you're Mexican.
        Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
        • ///digitalme
          • Dec 2009
          • 2088
          brake light light...that was a pain in the ass in my old e30 everything was new:bulbs, sensors, and still got that light but i think it has to do with the sensor on the brake pedal theres a sensor there???
          cause mine stopped doing that after i changed the little component that makes the lights light up...you know the little plastic thing that pushes against the pedal when you press it on and release it...i dont know what its called but i changed most of the stuff there and the light dissapeared
          • 88SuperETABD
            • Apr 2009
            • 911
            how do i short out my washer thing?
            • 88SuperETABD
              • Apr 2009
              • 911
              Theres nothing to fix for my washer fluid...because i deleted it...so might as well delete the light....and for the brake light...i want to FIX it...
              and that little clicker thing on the pedal...i know exactly what your talking about...mine went bad a while back...and i replaced it...so i doubt its that. (my brake lights were on all the time unless i lifted the pedal up.) heh.
              • StereoInstaller1
                GAS
                • 22679
                How to fix the brake light warning on the check panel has been written up many times.
                Simply; clean the diode pack and tail light housing connections.
                Closing SOON!
                Thanks for 10 years of fun!
                • kronus
                  • Apr 2008
                  • 13032
                  I got rid of my taillight check lights by putting in another check panel.
                  You can short the leads of the washer fluid sensor together to get it to think that it's got fluid there.
                  cars beep boop
                  • 88SuperETABD
                    • Apr 2009
                    • 911
                    i may be retarded...but by short....do u mean loop the current? like...tie them together...i dunno too much about electrical
                    • e30vert
                      • Jan 2005
                      • 1789
                      Yes to short means to connect two electrical connections. An open means there is no connection. When you connect the leads on each side of the washer bottle sensor it will "fool" the check panel into "thinking" that the fluid is always full. So the check panel light stays off.
