I recently removed my brake booster and fabbed up a dual master setup. I have never driven the car with it but I am nervous my braking is going to suck. Either to stiff or to much movement of the pedal. The car is mostly a street car so I kinda want stockish to a slightly firmer pedal.
I would like it to pass the "girlfriend test" i.e. You could put your girlfriend behind the wheel and , assuming she is a decent driver, she wouldnt rear end someone/go flying into a ditch.
set-up specs:
I changed the pedal ratio from ~4:1 to 6.2:1
Front brakes are 332mm rotors with 4 piston calipers 44mm and 36mm pistons
Rear brakes are 299mm rotors with 4 piston calipers 30mm and 28mm pistons
OE Porsche pads
are there any other options to running a remote mount booster? I dont want to run linkage all over the engine bay and a hydroboost system seems overly complex and I have head gives very weak brake feedback. I like the idea of boosterless, its simple, adjustable, fits in a small space(underdash). I just fear poor pedal feel. All the math works out but I have no real world expirence with this. Tilton has been less than helpful.
Thanks guys
set-up specs:
OE Porsche pads
Thanks guys
