Possible new buy
  • 325i 2 m3
    • Jan 2008
    • 4
    Possible new buy
    So ive been having terrible luck and problems with the e36 this past year and finally am at the point where i am contemplating something a little more reliable and better on gas. The car isnt running right now and i started searching for a new car. I stumbled upon a pretty nice e30 on a local forum i am apart of. Its a 1986 325e bronzit 5spd. The exterior and interior are in great shape with only a little rust on the sunroof. Owner says that the car runs and everything. Only known serious work needed is a new driveshaft put in as the u-bolt is bad. He bought the car for the 5spd to swap into his '87 325is.
    The owner has a new clutch that comes with the car so i guess if i were to buy it i could replaces the driveshaft and the clutch at the same time. Granted im sure there are a lot of little maintenance things that will need to be addressed, would this be a good choice for 1k? I dont have much $$$ so this is looking like an option.
    ~Blake~
  • ck_taft325is
    • Sep 2007
    • 6880
    If you buy it, I have a good drive shaft for you.
    *EDIT*
    I just clicked the link. That's bronzit, buddy... you should walk away.
    Need a part? PM me.
    • StereoInstaller1
      GAS
      • 22679
      A $1K bronzit with a known bad driveshaft?
      Driveshaft is like a $400 rebuilt purchase, and hard to find used in decent shape.
      You sure that car is worth $1400? I see more like $800, and only if the timing belt was recent, decent fluids, steering rack isn't leaking, etc.
      $800 INCLUDING that new clutch, too.
      Closing SOON!
      Thanks for 10 years of fun!
      • 325i 2 m3
        • Jan 2008
        • 4
        haha im not too worried about the color. At this point i just need a better vehicle.
        I am sure there will be other fixes and maintenance needed in order to keep it running well and be a good car. I am not worried about spending money on maintenance parts bit by bit within reason that i will not be having to drop thousands on it total.
        Things such as belts, fluids, t-stat, WP, anything like that i can handle, i just want to stay away from anything serious like a new steering rack, etc.
        I guess my question is, with 325 etas and the 5spd it has, what are some common e30 mishaps or known failures that i will probably need to address and be ready for. Example, e36 cooling system will need an overhaul at one point.
        ~Blake~
        • imdashiz
          • Sep 2009
          • 1373
          *EDIT*
          PSN ID: Yourself1
          • GotCone?
            • Jan 2008
            • 589
            don't expect your mpg to increase just by going to an E30. They 325 M50 is usually better on gas than the M20 even w/ the weight difference. However the NV M50 isn't as good.
            Build : Das Drehmoment Ungeheuer
            • hotballs
              • 1155
              You should be able to get any running eta for about $1k that doesn't have rust, need a clutch or a drive shaft...out here at least. :)
              • Streichholzschächtelchen
                • Jan 2009
                • 1670
                I heard you could use Mitsubishi parts to make a rebuildable driveshaft? Worth it?
                Jah bless! :pimp:
                • 325i 2 m3
                  • Jan 2008
                  • 4
                  Well what kind of gas milage are we talking here then. I've got a custom exhaust on mine that just killed the back pressure so I get about 18 or 19 per tank. I'd expect an eta to get about 25 with a 5spd and casual driving?
                  I've searched around and looked at places like www.driveshaft.com for a new driveshaft around 350.
                  ~Blake~
                  • Naplm00
                    • Nov 2008
                    • 1573
                    yes, if not better
                    my 325ic got a calculated 27 today. mind you this is ALL highway
                    88 325ic ~~~> Rusty and ugly
                    85 E ~~~> RIP
                      • Jan 2009
                      • 1670
                      Originally posted by Naplm00
                      yes, if not better
                      I've got an 325is with 300k on it. 19lb injectors, m30intake, and I don't drive for economy but I still get 27.1 avg, prolly 3/4 of the miles are around the town.
                      Jah bless! :pimp:
                      • Julien
                        • 7471
                        your OBC might say 27, you are more than likely getting 18-20 on a good day.
                        Build Threads:
                        • Julien
                          • 7471
                          http://nceuro.org/forums/viewtopic.php?t=11914
                          that is a terrible idea.
                          Build Threads:
                          • McGyver
                            • 4633
                            you could do better for 1K. just my 2 cents.
                              • Jan 2009
                              • 1670
                              How much does a full tank hold? I wanna set my trip odometer and do some math now. I average 90 miles a day shouldn't take too long.
                              Jah bless! :pimp:
