will an oil cooler out of a 1991 325is fit in my 1987 325is?
oil cooler
They have the same engines, but the front valances are different so mounting it up would be a problem. You could always get the late model valance and plastic bumper.
So it will work on the engine, might not on the car.Originally posted by cabriodster87"Honey? What color is this wire? Is it the same as that one? Are you sure? I don't believe it. OK, it works. Thank you sweetie."Originally posted by Kershawi've got a boner and a desire to speed.Comment
It should just be a direct bolt on. I don't believe the cooler on the later models were any different from the early's. They were mounted to the lower rad support i believe. I put a late model valence on my 87 and had no problems with the cooler.
John F. Kennedy
