clutch pedal question
  • SynSyx
    • Apr 2008
    • 542
    Normally I would post this under transmission, but I need to figure this out soon...
    When I went to start my car today, my clutch pedal was fully depressed to the floor, I started the motor but even with the clutch pedal down I couldn't shift into any gears (the shifter was giving me resistance as if the clutch was't engaged. So I turned off the engine and restarted it in first gear to see if at least the gears were engaging and the car jumped forward, so the transmission is still engaging gears.
    As for the clutch pedal, I can move it freely up and down and it will stay wherever I leave it, so whatever mechanism pushes it back up is not working... I pulled off the pedal cover and took a look at the pedal and its connections and I noticed that the little rubber dust cover on what I assume is the hydraulic had a hole in it, and there was a small puddle uder the transmission of a clear viscous fluid.
    So what happened here? Did the hydraulic shit out? Is it some connection of the pedal or is it an internal transmission/clutch issue? I'm assuming its just something with the pedal assembly since the transmission can still engage gears.
    I have all weekend to work on this if its something I can do myself, if not I can get it towed somewhere to get looked at...
    I'll post some pics tomorrow
    Thanks in advance
    BavAuto ~ Bilstein ~ BBS ~ Scorpion ~ MarkD ~ Prolumen
    Have you hugged a corner today?
    '89 335iC (M30) - summer
    '17 Mazda3 - winter
  • dashboardmonkey
    FUCK YOUR WAFFLES
    • Jun 2008
    • 6158
    crawl under and check the soft line and tighten the connections. See if you can see exactly where the fluid is coming from and go from there
    -Andy
    • lennon
      • Jun 2008
      • 1416
      check for leaks/fluid. probably failed clutch master or slave cylinder
      • E30Nova
        • 1546
        Either there's a hole/leak between the slave cylinder and master cylinder or your slave cylinder took a shit on you. Check all the connections, if there's a puddle on the ground, it should be obvious where something is leaking.
        Matt
        Matt
        I pack my CD player with asbestos. Those mother fuckers pay dearly for stealing my shit.
        Originally posted by kronus
        try whacking parts of the motor with a wrench while yelling "YOU WANT SUMMA DIS? HUH?"
        This is like a reverse build thread; it starts out nice and gets shitty.
        • PorkandBeans
          • Oct 2009
          • 75
          I have a similar issue, though not as severe. I believe my clutch master cylinder is weeping fluid. Never realised it until my brake fluid reservoir was on low and my brakes got squishy. There is fluid on the master and on the foam of the plastic cover panel down by the pedal. Let me know what you find, I was about to order this part but am deciding on whether to replace the lines and slave at the same time.
          1985 325e dd
          • Adrian_Visser
            • Jun 2006
            • 2823
            It's not a bad idea to do it all at once. That way you know the slave is new and you won't have to go through bleeding the system again for a while.
            '89 Alpine S52 with goodies
