Roll Bar
  • 619E30
    • 1753
    #31
    I get what your sayin. But what diameter pvc would I need to be strong enough?
    Originally posted by audiquattrot
    bimmers b4 b*tches....remember that.
    1990 Alpinweiss 325i - secret 500whp build
    2000 Audi S4 B5 Laser Red
    1990 Nissan 240sx - Drift Missile
    2006 CBR600RR
    • Danny
      • 14217
      #32
      You'd probably be safe with 1/2" but I'd go 3/4" just to be safe.
      • 619E30
        • 1753
        #33
        What thickness?
        2006 CBR600RR
        • Danny
          • 14217
          #34
          Just talk to the guy at Ace Hardware/Home Depot/ Lowe's and let him know what you're building, he'll point you in the right direction.
          • Stephen
            Шлем ишака
            • 10774
            #35
            For the really crucial spots i put a smaller pipe inside a larger one, but that's your call. Also farm supply stores are a great place to go. Plenty of PVC welding experts too
            • 619E30
              • 1753
              #36
              Okay. Sounds good. Thanks for the help.
              I'll definately keep that in mind.
              But I'm kinda stuck on how to bend the pvc? Use angle connectors?
              2006 CBR600RR
              • Jesse30
                • Jan 2007
                • 3936
                #37
                me and stephen used angle connectors SOLEY FOR MOCK UP, for final roll bar assembly. you need to heat the pvc piping up to 345* C to melt the plastic but avoid ruining the molecular structural integrity of the pvc. this is key. you need to get a laser temperature gauge to make sure you get it at the right time. otherwise you're back to square one.
                • Stephen
                  Шлем ишака
                  • 10774
                  #38
                  ^ yep. Dont worry it sounds really finnicky and complex and what not but its a snap after the first few tries. Do some practice bends
                  • IminDiegoTriick
                    • Oct 2009
                    • 1564
                    #39
                    i know its far but its well worth it. Fabrication is done at the highest level. Welding is top notch. This is one of the beasts worked on by them.
                    keith ta (revdupkustomz)'s profile on Myspace, the place where people come to connect, discover, and share.
                    Fast life fuck slow..Low life for life
                    Let the mix flow..Let the night flow
                    I'm so gone ✗ ♥ O
                    • Luis325
                      • 3847
                      #40
                      Impresive......
                      1986 "C2 2.7 Alpina" Sedan
                      1987 325ic Black Vert
                      • 87-325ic
                        • Apr 2006
                        • 1198
                        #41
                        seriously guys.. ?? hilarious.
                        but doesnt the PVC squeak too much when you go around turns.. or does the welded pvc not do this? and OP, you should definitily use at LEast 1" OD if youre goingwith pvc, 25% stronger and olny 10% heavier than the3/4"
                        • Moberg12
                          • 209
                          #42
                          • Mr Two
                            • Jul 2008
                            • 590
                            #43
                            This is the best thread.
                            • Syncro325is
                              • 574
                              #44
                              When I did mine, I used that spray foam to insulate and secure the pipes. No squeaks or anything, and its solid. Shit it impressed the hell out of those dumbass d-bags at the track. They all begged me to take out their heavy steal cages and replace them with the lightweight PVC cages. This is some cutting edge shit right here.
                              • JGood
                                • Jan 2004
                                • 7959
                                #45
                                I like to use these connectors at the joints on the main hoop. That way, if you ever decide to go with a full cage, you can simply add on without taking apart the old roll bar.
                                e30 restoration and V8 swap
                                24 Hours of Lemons e30 build
