stupid question time.... dog-leg tranny
    i've heard people talk about a rare euro dogleg tranny... i had no idea what it was... but when I got my 928, i noticed that the shift pattern is way different than other german cars. Does dogleg refer to the shift pattern?
    I have...
    R24
    135
    would that be a dogleg if it was on an e30?
    Michael Spiegle
    '01 Ford Escape / Daily Driver
    '99 M3 / Track Car
    '87 325is bronzit / wtf car
    '06 Daytona Triumph 675 / Daily Rider
    Yes
      sweet. I've been driving around my friend's new '99 m3 and just thought that my shift pattern was much more efficient than the standard pattern.
      Michael Spiegle
      '99 M3 / Track Car
        Whats the advantage to having that shift pattern? For the track I might see an advantage because you very rarely use 1st gear. But normal daily driving I dont see too much of an advantage to it.
        Will
        RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
        Welcome e30 (brilliantrot '90 325is) 12/23/06
        DaveCN = Old Man
        My signature picture was taken by ME! Not by anyone else!
        If people keep quoting me in their sig, I'm going to burn this motherfucker down.
          well quick shifts from R to 1st... thats about it as far as i see.
            The point is for use on the track.
            Also IIRC the dog-leg box is also close ratio meaning that 5th gear is 1:1 instead of over drive and the cars that came with them have a taller final gear ratio.
              1st is only used in the pits and R is used if you fuck up. 2,3,4,5 are used more often, so keeping them in the H pattern means more efficient shifting.
                I agree with e30sd. If your car is moving, you shouldn't really have to shift into 1st. In city driving, I use 2nd and 3rd the most which are right in line with each other.
                Michael Spiegle
                '99 M3 / Track Car
                  that's exactly why.. and secondly you rarely get this trans and have it not be a close ratio box. with the closer ratios, first gear is semi to completely useless, so this makes the adjusted gear pattern that much more necessary
                  PNW Crew
                  90 m3
                  06 m5
