1988 325 super e head question?
    I read about this but i get confused on subject.
    I have a 885 head comes in my car.
    the head gasket went so i saw a small chunk on the water port to close to cylinder seating.
    so i need to change head to play it safe.
    what is the real difference of the 325i 885 head?
    i noticed i don't have double valve springs.
    and i read there's different cams.
    I was told the 2 oil passages are different? is that true with same casting head?
    if so can it be used on car that way?
    my goal is since i have to change it why not do the double valves and cams get the extra hp.
    my 885 head has sinlge valve springs
    88 325ic
    88 325ic ~~~> Rusty and ugly
    85 E ~~~> RIP
      i'm more confused thanks lol
        si i can look for double valve springs .what about how to identify different cams?
          100% slap a i head on there and then an i ecu and ur set
          Then sell yours and make your money back!
          1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
          1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
            i have a 1988 super e don't i have the right ecu?
              not for the rev limit!
              and to get the most from the top end power you will gain with the i cams
