Tapped out?
  • Mafiaracers
    • 353
    Tapped out?
    So it was a sunny day and I just so happened to be driving the old girl down a certain stretch of highway when I noticed I couldn't see anyone...as far as I could see down my portion of the freeway, there were no cars. So I settled into my seat and said "oh why not." I dropped it into 4th and took it to about 100...got there surprisingly quick, just touched the top of redline then popped her into 5th. It climbed to 115 pretty easily, but then tapered off, 120 was all I could squeeze out of it. I don't know if the aerodynamics caught up with it or the age of the car or what. Only mods are billys/HR and trunk tar removed and 3.73lsd. I keep up on the oil/filter maintenance religiously...car runs like a champ. It was the first time I've "maxed" it out and kinda felt let down...probably the wrong word, but I was like, "that's it?"
    I know top speed isn't everything, but I sat there thinking, hey, there's 30+ more MPH left on the speedo...wtf.
    Anyone else with this experience?
    Chris Woods
    https://www.facebook.com/munichmotorworks
  • nrubenstein
    • 3148
    The car should definitely do more than 120. My friend Mike is hitting an indicated 135 (probably an actual just over 125ish) on the front straight at Summit in his SE30.
    Realistically, the top speed should be in the 130s. 120 is low for the car.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • E30SPDFRK
      • 5716
      My 318is did 135, so you should be able to do at least that. That was with a 4.10 sitting at 6700
      ninja edit: what engine?
      Byron
      Leichtbau
      • george graves
        • 20003
        Originally posted by Matt-B
        • lennon
          • Jun 2008
          • 1416
          do cars normally max out their speedometer?
          i was just driving my friend's mitsubishi galant 2.4L 4cyl today and the speedometer goes to 150/160 but i wouldn't expect it to do that, nor would i ever try.
          anyways... if your car is a 325i, you should be able to hit an indicated 130mph. but why...?
          • Be30mer
            • Jan 2010
            • 1121
            Im guessing you have an m20b25 powering your car. 3.73 lsd is taller than standard differential, so that could be it. 120 mph is fast enough, dont go crazy on mods so you can surpass that. And remember, e30's are bricks, not knives, aerodynamics are not an e30's friend
            You are lucky your Dad didn't pull out and leave you on the passenger side seat.
              • 34844
              what? 3.73 is stock for a 325is 5 speed..
              • Be30mer
                • Jan 2010
                • 1121
                he said it was a mod though...
                • Mafiaracers
                  • 353
                  Its an 89 325is 5spd, g260, 237k on body and about half that on the motor, 14" weaves. Doesn't burn oil, doesn't smoke...maybe it's just old. Not like I'm all that worried about it, I have a twin-cam in the works but I was just surprised at the outcome today.
                  Chris Woods
                  • Moberg12
                    • 209
                    Check the DME!! The 525 and I think the 526 are both top speed limited.
                      • 34844
                      this is true
                      • Mafiaracers
                        • 353
                        Oh, so I may have a "governor" on my computer? The computer in the glove box? And only way to fix this would be to.......?
                        Chris Woods
                          • 34844
                          swap computers
