i just got another 85 325e. I want to cut the springs, but noticed that there shaped like a bee stinger. just wanted to know if anyone had pointers on were to cutt them and how many coils i can do for a good stance on the car.
cutting springs
Tags: None
You should make a proper intro to r3v before asking any questions. But welcome!1990 Alpinweiss 325i - secret 500whp buildOriginally posted by audiquattrotbimmers b4 b*tches....remember that.
2000 Audi S4 B5 Laser Red
1990 Nissan 240sx - Drift Missile
2006 CBR600RR
Bart Simpson, he doesn't need to do that...this isn't group therapy.
You might get flamed for your request on "cutting springs," since this is a topic that has been convered numerous times and most original posters are just cheap dumbasses. Cutting isn't recommended nor safe, but here is some reading material on the matter.
Using the search function and narrowing it down to the suspension subforum would do the trick just so you know in the future, but here's some reading:
Now if you are looking to not half ass the job and buy springs, then us on the forums will help you get the ride quality you want by recommending what suspension would work best for you and your budget.
SC*AR (Schwarz Army)
No longer stock ride height, rolling as low as a daily driver in New England should without worrying about breaking an oil pan. :up:Comment
I'd like to see your proof on this. I have one full dead coil cut off from the top, on the fronts of my IE3 springs. I have since been on many long drives, including several autocross events and noticed or experienced NO adverse handling effects and no change in ride quality. My car has not once felt unsafe in a corner or at speed since removing the one coil at the fronts.Comment
Josh, it doesn't take a rocket scientist to work out that cutting a spring will change how it acts through its range of movement. Most people cut too much, which makes it hugely dangerous as the spring can't stay captured between the perch and the top-hat and will fall out. Nah, that's not dangerous at all!I'd like to see your proof on this. I have one full dead coil cut off from the top, on the fronts of my IE3 springs. I have since been on many long drives, including several autocross events and noticed or experienced NO adverse handling effects and no change in ride quality. My car has not once felt unsafe in a corner or at speed since removing the one coil at the fronts.
How is any coil in a captured spring "dead"? Were your springs too big for your shocks or something? I reckon if you put proper springs/shocks in your car, had them set-up properly (with no care/consideration for how it looks) it'd handle and ride much better. I honestly cannot see how anyone could think cutting a piece of your spring off won't significantly affect the action of the spring - it's not just bits of scrap tube wound around a few times and cut to length!
Cutting springs is retarded - if aesthetics mean so much, get coilovers and do it less dodgily.Pork Hunt Motorsport
eBay is like the summit racing catalog for today's special Olympics crowdComment
Truthfully Josh I have none other than reading that the general consensus throughout this board deems it as being something to do very carefully so its not recommended. It can be done retardedly wrong. I can't give members credit for being smart enough to not fuck things up.
I never said it would not change the spring rate or affect its range of movement. That's just plain common sense. I wanted the front to be slightly lower, and I wanted to see what, if any, negative effects would stem from it. Since I've had these springs for about 3-4 years, and I am planning on going to coilovers soon, I said fuck it and took a whack at it. Or a cutting wheel, if you will.Josh, it doesn't take a rocket scientist to work out that cutting a spring will change how it acts through its range of movement. Most people cut too much, which makes it hugely dangerous as the spring can't stay captured between the perch and the top-hat and will fall out. Nah, that's not dangerous at all!
Cutting springs is retarded - if aesthetics mean so much, get coilovers and do it less dodgily.Comment
I believe springs are progressivley different resistance troughout the coil, if Im not mistaken. As the spring contracts, it gets harder to press. Its built like that on purpose to prevent it from bottoming out. We all know, cutting springs is cutting corners and cutting corners on something as important as an important a piece of suspension as the spring cant be completely safe. Yes, chances are that nothing will happen, but you must at least agree that its not as safe as getting lowering springs. No? Plus its readily obvious that the thread originator is new to this concept and we dont want to give the impression that this kind of behavior is widely accepted. Plus it doesnt look like the correct amount of knowledge as to how/where to cut the springs is there. I dunno, I just wouldnt do it, what with springs not being that expensive.
Im gonna feel real stupid if something Ive held to be fact for all this time turns out to be another myth.
I will heartily agree that doing something like cutting large amounts of material from STOCK springs to achieve the same drop as true lowering springs is half-assed, cutting corners, and likely fairly unsafe. In my defense, I took only one coil off the top, with a total drop of about a half-inch, probably less.Comment
that cool and all how much is to much i just want my car to look sick and no i dont have the money for coil overs so... 2 rear 3 frontComment
