What oil weight is everyone using?
    • 34844
    #106
    Originally posted by Mike30e
    Said to be a top quality oil, but too thin? Engine does not burn any oil and is fairly quiet...
    his car was a rusty POS. I wouldn't neccesarily listen to him. ;)
    • briansjacobs
      • 1278
      #107
      I highly recommed refreshing your motor before you need to rebuild your motor.
      Brian Jacobs
      • E30 331is
        • Sep 2011
        • 1166
        #108
        Previous owner used 20w-50 with 1qt synthetic... anyone make their own blends?
        • immajackuup
          • Dec 2010
          • 1132
          #109
          0w40 or 10w40 depend where you live at,20w50 is too thick and will damage bearing little by little on start up.
          • 5Toes
            • 9836
            #110
            15w40
            • bmwsun
              • 388
              #111
              5w40 synthetic total
              M3 springs w/bilstein hd's, IE 22/19mm sway bars, front IE stress bar, complete suspension rebuild, IS interior.
              Crew chief for BBQ2U Racing: James Crivellone, John Parker, Chris Anderson, Ben Wilson, George Howe, Will Kellog, Jim Cissell
              BBQ2U Racing, Best of Intentions Racing
              • e30strokr
                • 211
                #112
                I used 5-40 regular oil, most damage happens at startup so I want the oil getting thru the passages ASAP!, the 3k or 3 months change is what the oil companies want you to do ;) for the experts in here is Mobil "synthetic" Group III or Group IV again?
                • e34john
                  • Apr 2006
                  • 3599
                  #113
                  10w40 but last time I used 20w50 just to see if it would leak less.
                  • Irish1
                    • Mar 2005
                    • 279
                    #114
                    I use the Amsoil high zinc 20-50 weight. My M20 has 202,000 miles and burns about 1/4 of a quart every 2500 miles. That's acceptable to me.
                    • QUKBMER
                      • 8178
                      #115
                      redline syn 20w50
                      • ///digitalme
                        • Dec 2009
                        • 2088
                        #116
                        10 w40 is what my m42 likes...
                        • Jaxx_
                          • Dec 2009
                          • 1880
                          #117
                          15w-50 mobil1 synthetic
                          • TurboJake
                            • 3780
                            #118
                            Castrol 20w-50 Spring/summer/fall
                            Delo 15w-40 winter.
                            Leave Me Transaction Feedback
                            • SUICIDE109
                              • Jun 2010
                              • 326
                              #119
                              10w 30 Mobile 1 full synthetic because I live Michigan, summer months I'll put a heavier weight in.
                              Originally posted by devon.818
                              low key i actually paid attention to the drifting...then saw bouncing tits and went :o
                              as for a 4hr boner...idk, start using it for things; cup holder, dial the phone, type with it, fix things, diagnose the e30, probe random shit...
                              Originally posted by Mercury[BKM]
                              ...because Machine Gun
                              • pantelones
                                • May 2011
                                • 533
                                #120
                                This is a good thread, my search of ZDDP (Zinc Dialkyl Dithiophosphate) brought me here.
                                I was on the I.E. site and they say to go to this web site if you are using a preformance cam, and/or have other mods done the the m20.
                                Has anyone used their products? Or would if be better to use an oil with a higher amount of ZDDP already in it?
                                I thought this was pretty interesting too...
                                Originally posted by cobraken
                                That’s when the powers that be in Washington (read as the Environmental Protection Agency - EPA) decided that the percentage of zinc additives in passenger car motor oil was too high and was destroying catalytic convertors and therefore polluting the air. Well, we all want cleaner air and longer life in our catalytic converters, so I can’t fault the government. Alright, maybe just a little, but you see they failed to tell us something. With “us” being the flat tappet push rod people. You know, the solid and hydraulic lifter camshaft people, and you know who you are.
                                I just put some 5w-30 in my car since it hasn't been running much due to being restored, but after I get it going I plan on putting some proper oil in it.
                                It seems to be that Mobile 1 15w-50 seem like the best choice for the summer.
                                Originally posted by nando
                                mobil 1 15w50 actually has decent amounts of ZDDP
                                So would it be a good idea to add a ZDDP additive? Or just run it as is?
                                A man chooses, a slave obeys... Would you kindly?
