Screw it, I'm keeping it. 325i Bronzit
  • KillaCams
    • Mar 2008
    • 998
    What's wrong with the wiper motor? Try jimmying the wiper switch back and forth while moving it up and down, if the wipers work you need a new switch. Had the same problem with mine when i bought it, changed the switch now it works perfectly.
    • BrooklynMW
      • 1263
      Originally posted by b*saint
      Who the hell tries to return a car to the po?
      When the PO outright lies about half the problems with the car. I mean flat out lies. Not not telling me, but lying. Also we made an agreement. As is, but as is after I drive it home. Sure enough I discovered most of his lies as I first drove it home.
      '87 325i "Chewey" (RIP, my beloved)
      current:
      '01 e46 325iT "Dot" - #datwagonlife
      '87 e30 325i "Tui" - she has her mother's eyes
      • BrooklynMW
        • 1263
        That's exactly what happens. Thanks!! Good to know all I haw to change is the switch
        current:
        • accident
          • 7303
          is the cruise control stalk loose? if it is tighten it. the ground for the wiper stalk grounds at the same place the cruise control screws on. had the same problem.
          Moral of this story?
          • SamE30e
            • Sep 2007
            • 4319
            Originally posted by blunt
            that chick in the last pic looks hot
            Good eye.
            1985 325e 2.8 Turbo VEMS
            • BrooklynMW
              • 1263
              Thanks, fellas, for the wiper advice. Now I have at least one small item I can cross off my list
              current:
              • KillaCams
                • Mar 2008
                • 998
                What's up with the window switches and fuses?
                • bimmer_E30
                  • 5001
                  Chicks dig the bronzit Hotness.
                  Glad you're keeping the car, don't be an idiot like me and sell them after 3 Months Lol :p
                  Originally posted by e30e
                  • BrooklynMW
                    • 1263
                    The front passenger window has a hard time closing, but makes it eventually. I hear this is a common problem and an easy fix. It's definitely the button, and not the window motor. I know this because if I push the button over to two one side, and only push it down about halfway, the window cones right up, one of those problems.
                    Not 100% sure about the fuses, just wanted to check em out. There are a couple of minor issues that are either fuses or not. Such as the light on the right side of the instrument cluster. The tach and temp gauge don't come on. Also the driver doo only locks from the inside, and when the door is closed....but it doesn't have power locks, so I'm sure it's something to do with the latch or the lock cylinder.
                    Also, the drivers side rear door is jammed shut.
                    Just wanted to check the fuses
                    current:
                    • BrooklynMW
                      • 1263
                      Speaking of Bronzit, the paintjob is the last issue I'm going to address, but would like to know what to do. I'm not sure if it needs a complete paint job, or just some touch ups. Or clearcoat. What's clearcoat?
                      current:
                      • bimmer_E30
                        • 5001
                        Clearcoat? it's the Final Stage or i should say the Final Stage of painting....
                        Bondo-sand-mask-tape and Paint, i work at a bodyshop and we use "water based" Paint rightnow, they used to use "oil based"....so yah it's the final stage of painting. After you do put the clearcoat, let it dry and wetsand+buff and put Your shine on'
                        • 619E30
                          • 1753
                          You said you can go just a touch over $200? Spend the extra: JVC KD-R900
                          http://www.r3vlimited.com/board/showthread.php?t=170374
                          Aiwa CDCR217
                          Originally posted by audiquattrot
                          bimmers b4 b*tches....remember that.
                          1990 Alpinweiss 325i - secret 500whp build
                          2000 Audi S4 B5 Laser Red
                          1990 Nissan 240sx - Drift Missile
                          2006 CBR600RR
                          • MrSlacker
                            • 2494
                            Looks like you have a good list going. You should contact Denis (dude8383) and see if he can do some of the work for you. He is the master E30 mechanic and will charge you MUCH less than a shop ;)
                            My Seller/Buyer Feedback
                            Performance Aftermarket Parts & Accessories
                            • accident
                              • 7303
                              If it wont lock from the outside you need a new cylinder, however the door lock is made to not be able to lock when the door is open, to keep you from locking your keys in the car
                              • BrooklynMW
                                • 1263
                                That sounds like the time consuming and expensive method that I was hoping to avoid. Of course, if I have no other choice, and I must go through the process, the car is being painted black. http://www.r3vlimited.com/board/imag...es/bronzit.gif
                                However, if all I need are some touch ups, then I'll stick to bronzit and go the cheap route. All that really needs repainting is the hood, roof, and front fenders (were obviously replaced at some point).
                                And the pinstripe needs redoing as well.
                                current:
