Cluster wire ???
  • barry
    • 1642
    Cluster wire ???
    Hi Guy's
    Ok so there is a green block on the back of the cluster that accepts one wire.. There are three vertical holes available, does it matter which hole the wire goes in? The female connector is black and has a round hole. The green block on the cluster has a pin. I'm almost sure this is something to do with the cruise control.
    Any help would be appreciated. Next time I will mark the location...
    Thanks
    Barry
  • sector6
    • 909
    Originally posted by barry
    Hi Guy's
    Thanks
    Barry
    Lol, I'm in the same boat. I'm pretty sure it is CC. I don't ever use it, but it would be nice to know where it was suppose to be put.
    • barry
      • 1642
      <LLLOOOOOOOOOOOOOLLLLLLLLLLLLLLLL
      I will let you know after I go for a spin, I put it in the top to start...
      Catch ya later
      • craiggroves91
        • Oct 2009
        • 3024
        I just did this today too!! hhaha
        I put it in the middle cause i noticed the connector said 2 so i figured that might mean something. Everything is working properly. I dont use cruise control nor does it work so who knows.
        1989 BMW 325i SOLD
        1998 BMW Estoril Blue e36 M3/4/5 SOLD
        1987 BMW 325 (The Piece) SOLD
        1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
        • barry
          • 1642
          Ok Guys just got back from a spin around the block. Stick it in the top one and it works great, Resume, coast etc. all work
          GL
          Barry
          • woodisgood
            • 1087
            Hmmm, i just did this too, except mine had two wires for three slots, I put them in the top two, cluster all works now but maybe I should check the cruise....
            • Jean
              • 18228
              If you look at a spare green block you'll see which ones are the same ;) Easily can be confirmed with a test light or dmm .
                • 34839
                yeah, any of the green plugs is fine, they're all MPH outputs.
