Went to the dyno to tune some bad spots out, ended finding out I had a few more issues than I would have liked to encounter on the dyno.
However after sorting through all the problems, I was able to do a very slight amount of tuning, out of the two hours I rented.
End result isn't bad.
320wtq/310whp @14psi
stuff related to the setup:
m20b25
84.5mm ceramic coated Wiseco 8.5:1 pistons
lightened s50b30 rods (arp bolts)
12.9 main bolts
crank scraper
O-ring'd block
Stock goetze headgasket
ARP Head studs
R&M Adj. cam gear
mediocre front mount IC
custom FP big wheel gt30r
38mm Tial wastegate set @ 14psi
Blitz Supersound DD
42lb Lucas injectors @ 3.0bar
MS2 EMS + AEM UEGO Wideband
msd blaster 3 coil
ngk bpr7eix (.025")
3" stainless mandrel straight pipe
M1 10w40 synth oil
NO OIL COOLER (looped cause it broke)
-Derek
DedericMS
m20b25
12.9 main bolts
crank scraper
O-ring'd block
ARP Head studs
R&M Adj. cam gear
Blitz Supersound DD
msd blaster 3 coil
ngk bpr7eix (.025")
M1 10w40 synth oil
-Derek
DedericMS
