Kamotors' Track intake
  • kamotors
    • Nov 2007
    • 7102
    Is anybody interested in an intake kit that will replace the high beam with an ITG filter? Advantages would obviously be no need for a heat shield and a larger and more direct volume of cold air than stock. In my testing just going to a more direct, larger diameter duct decreased IAT's by about 15 degrees. Having a properly shielded AND ducted intake can decrease intake temps by over 50 degrees when compared to your average cone filter setup.
    I can do 3" or 3.5" inlet diameters and will use pre-bent tubes(not flex hose) to the AFM/MAF. ITG rates the 3" filter good to 310 BHP and the 3.5" good to 450bhp. This is a foam filter so it does an excellent job on filtering. There is a reason dirt bikes use oiled foam filters, they simply filter dirt way better then paper and gauze. I will do at least a limited run on this kit just to test the market, if these sell well I'll continue to stock them.
    (I got bored with p-shop)
    7speedshop.com
  • Luis325
    • 3847
    How much?
    1986 "C2 2.7 Alpina" Sedan
    1987 325ic Black Vert
    • kamotors
      • Nov 2007
      • 7102
      ITG filter alone is around $85 so the total kit with couplers,clamps,and aluminum piping will be around $140-$150 shipped.Could be a lot cheaper if I can get a cheap supplier. It will be E30 specific so you don't have to worry about it not fitting right.
      7speedshop.com
      • dude8383
        • Jan 2005
        • 10387
        Hmm I might be interested in just the filter. Can we get a pic of the filter by itself?
        • kamotors
          • Nov 2007
          • 7102
          no interest? What If I just started selling 3" and 3.5" ITG cone filters?
          7speedshop.com
          • eLKuRLy
            • Oct 2007
            • 360
            Originally posted by dude8383
            hmm i might be interested in just the filter. Can we get a pic of the filter by itself?
            +1
            • mutty
              • 290
              Would buy the kit.
              • markseven
                • Sep 2006
                • 5327
                I'm interested in the kit... why are you calling this a "track intake"?
                I Timothy 2:1-2
                • kamotors
                  • Nov 2007
                  • 7102
                  I would not recommend an air filter sticking out the grill and losing a high beam good for the street. I would use it for things like auto-x
                  7speedshop.com
                  • Balleristic31
                    • Aug 2009
                    • 4198
                    also interested in just the filter
                    -NICK
                    • eLKuRLy
                      • Oct 2007
                      • 360
                      any word?
                      • alpinee30m50
                        • 647
                        Id be interested, would it work for m50's? i dont see why not
                        86 Zinno es
                        M50 inside
                        • Luis325
                          • 3847
                          Updates!
                          • kamotors
                            • Nov 2007
                            • 7102
                            still going to work on it, just been short on money.
                            7speedshop.com
                            • OdSkE30
                              • 375
                              I'll buy just the filter from ya if you don't mind splitting the stuff up like that.
                              -Joe
