Okay, I have a 86 2.7l eta block, want to know if I can simply just swap blocks with my 87 2.5l 325is to make it a stroker. Will timing belt be the same and will the stock ecu work. Any other problems? Will run okay at high alltitude if it gets low compression from this setup.
TIA
Doug
TIA
Doug
