e30 touring tailgate.
  • 16v of E30
    • 157
    I know this is a longshot, but how do you remedy a squeaky tailgate on an e30 touring?
  • Danny
    • 14216
    lube
    • DRTSRFR
      • May 2008
      • 1836
      This/\
      If the rubber gaskets are squeaking, you can use baby powder as a lube.
      Suspension tips here...
      http://www.r3vlimited.com/board/album.php?albumid=757
      • structured
        • 954
        Give it to me. You will never hear it again.
        • Chabs
          • Jan 2010
          • 538
          or WD-40
          Josh
          http://www.r3vlimited.com/board/showthread.php?t=159843
          • SpecRaceM5
            • 956
            Is it squeaking when opening/closing or when driving? It's a long shot, but the newer BMW's sometimes have problems with seals creaking when driving which can be remedied by teflon tape on the body where the seal rests.
            • 16v of E30
              • 157
              i was more thinking around the lines of the hinges being loose.
              alright hotshot, lube is the answer, but after looking at it, i dont see any spots i can grease it up.
              • Red88
                • Nov 2008
                • 1161
                That's because the car is in your driveway, not mine.
                Have you made a purchase from www.blunttech.com recently?
                sigpic<< wrecked
                • lgb240
                  • 204
                  [quote=16v of E30;2054757]i was more thinking around the lines of the hinges being loose.
                  I don't think the hinges are the issue ... make sure that the latch / hook are aligned properly and tight. Also, there is a rubber bump stop on either side of the tail gate that mates to a reciever on the body when closed - make sure that these bumpers are screwed out far enough that there is some tension on the gate when it's closed. If these bumpers are old, stiff or rashed, get new ones.
                  Lastly, make sure the squeeks and rattles are actually from the hatch ... the 2 storage compartment doors and all the misc. stuff packed inside could be the source of the noise (they where on my Touring)
                  good luck
                  lgb240
                  lgb240
                  `05 E46 325xiT, `89 325i Touring, `87 911 3.2, ' 74 Caterham Super 7 , `71 240z Convertible, `71 240z, `67.5 2000 Roadster, `58 MGA x2, '56 MGA vintage racer, '04 Mini Cooper S
                  • Charley
                    • 396
                    The latch/hook was the problem on mine, it had to much play...
                    quick tightening solved the problem.
                    Charley
                    • 16v of E30
                      • 157
                      duely noted. lock and hook. i will go take a look.
                      plus i am missing one of those bump stops on the right side of the tailgate...bummer
                      • 16v of E30
                        • 157
                        done! thanks charley. i got a poutine with your name on it...
                        • kid325e
                          • Sep 2007
                          • 6421
                          uhhh what is a poutine?
                          clutchCTRL!
                          Move with a purpose.
                          - 1991 325iX 4dr/5spd
                          - 2000 323i AT
                          2016 Mazda CX3 Sport AWD
                          • Massive Lee
                            • Sep 2006
                            • 6785
                            Hmmm.. Poutine. The ultimate craving buster.
                            Crispy frieds + cheese curds + BBQ gravy
                            massivebrakes.com
                            • 16v of E30
                              • 157
                              if your not canadian or french for that matter, you are missing out on one of the finer things in life.
