Speedometer works Intermittently
  • Killacortes
    • 1937
    So I was driving today and my speedometer wasnt working. Parked turned it off and went back on the road and was working again. Does anyone know what could have made it do that? Speed Sensor? A blown fuse wouldnt let the speedometer work at all. And all the other gauges work fine Tach, fuel, etc....
    r3v does not fuck around. First you get banned, then they shoot you
  • dashboardmonkey
    FUCK YOUR WAFFLES
    • Jun 2008
    • 6158
    speed sensor in the diff
    -Andy
    • reelizmpro
      • 9552
      Most likely the speedo itself.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • kway
        • 1084
        This. Next time it goes out try banging on top of the dash and see if it comes back. I've heard of people having luck with reflowing the solder joints, but I've never had any myself. Last time I needed one done I sent it to Bill Auberlen's dad's speedo shop in Cali. Forget the name right now but I'll post it later. North Hollywood Speedometer is supposed to be pretty good too.
        Edit: Paul's Speedometer Service: (310) 374-3017 http://www.yelp.com/biz/pauls-speedo...-redondo-beach
        His dad's not named Paul, but that's another story.
        '84 318i - Lapisblau/Schwarz (in cryosleep)
        '06 330i - Titansilber/Schwarz
        • Mike
          • 932
          I can remove the kick panel, and tug on the harness that is the most left side of the cluster, and the speedo comes back to life. I do it while the car is at speed, and the kickpanel had been long since removed. I forget which pin numbers in the white plug are responsible for speed signal, but you test them looking for open/close as you roll the rear wheels.
          Supatek -noun - your basic know it all
          • Killacortes
            • 1937
            I heard there were soldered on batteries in the back of the speedo, but you have to get a whole new speedometer is that right?
            • Vince30
              • 2318
              Buy a gps
              • kway
                • 1084
                You're thinking of the SI board.
                • gone002
                  • 880
                  check the back of the diffy... theres a cable that comes out and gets loose.. mine was
                  i did the battery thing didnt do shit!
                  bimmerboltsandparts.com
                  bring back the neeked broads!!!
                  • Killacortes
                    • 1937
                    fixed the speedo! got a new speed sensor
                    • Cabriolet
                      • 9620
                      i had the same thing happen on my 86 325es and it was the gear dying. replaced the gear and now it works 100% of the time.
                      Much wow
                      I hate 4 doors
