Meow.
  • porkchopsandwiches
    • Jun 2010
    • 6
    Meow.
    Yep, I'm new.
    Out of 8 cars so far, this is the first rwd thing I've owned.
    Basically your typical clapped out rusty run of the mill '86 325. No clue how many miles on it, as the odo was apparently stopped at 220k when the PO bought it, and he swapped clusters in an effort to make the speedo work (which it still does not). I traded a saab 900 turbo for it.
    Someone did care about it, though, as it has an MSD coil, bavauto wires, a full stock I exhaust, and the suspension is in decent shape. And an LSD that works nice. I was pleased to find this when I cracked open the ECU.
    I need to change the front strut bearings and fix the cluster now and plan on doing a tbelt, diff fluid and trans fluid change, a new guibo and support bearing, and rebuilding the shift linkage within the next couple weeks. Should make a pretty solid beater. Will probably also fix the ac and swap in cruise and a 13 button obc at some point.
  • sector6
    • 909
    Welcome, looks like a good platform to start with. GL
    • 325ix
      • Aug 2009
      • 7783
      Welcome. Looks pretty nice. Mudflaps and roof rack look good. I should have both of those things on my car soon.
        • Jun 2010
        • 6
        Ha, the roof racks I had kicking around for a vw rabbit I have, and the mudflaps came on it. Did those mudflaps come on all e30s?
        • ak-
          • 12422
          Looks clean.
          I'd like two things on your car I don't have:
          1. A second bike attachment.
          2. Mudflaps.
          Welcome!
          1991 325iS turbo
          • Holland
            • Nov 2008
            • 7212
            Not too many E30's have mudflaps. BTW is your username from what I think it is?
            Originally posted by DEV0 E30
            • Farbin Kaiber
              Lil' Puppet
              • 29502
              Greasy, served in an ash tray.
              • chadthestampede
                • Jul 2008
                • 3601
                gi joe?
                Originally posted by LJ851
                Feedback
                • Farbin Kaiber
                  Lil' Puppet
                  • 29502
                  • Holland
                    • Nov 2008
                    • 7212
                    gi joe?
                    Damn straight.
                      • Jun 2010
                      • 6
                      And after soldering a new pigtail onto the leftmost plug of the cluster (the white one), the speedo works and the rest of the cluster is no longer crazy.
                      Awesome.
                      These cars are really quite reasonable to work on. Everything makes sense. The last few cars I owned were old saabs, which were less than a treat for fixing even trivial things.
                      • tg318is
                        • Jun 2008
                        • 2052
                        welcome! DL with it :D
                        Tim.
                        • quikveedb2
                          • Sep 2007
                          • 2258
                          Originally posted by tg318is
                          DL with it :D
                          wat? dirty luck? douche-y luck?
                          You know why you're drinking that Pabst? No its probably not because it was the first beer you grabbed. It's because you're a winner.
                          • TexasTerp
                            • Jan 2009
                            • 3541
                            very nice! looks like you got a great start! welcome to the beast that is r3v
                            stephenbrody.com
                            • Streichholzschächtelchen
                              • Jan 2009
                              • 1670
                              Ay flapjack whats good with those rear mudflaps shipped to 94501 cali. Nice car has potential.
                              Jah bless! :pimp:
