Different mtech 2 wheels both fit?
  • PeaveyBassist
    • Sep 2004
    • 3511
    As some of you know...there are 2 different mtech 2 wheels. I know some of you have the Mtech 2 steering wheels. Do they bolt right in? Straight swap from factory SRS wheel?
    Does the 2nd one bolt in just like the 1st one?
    Will
    RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
    Welcome e30 (brilliantrot '90 325is) 12/23/06
    DaveCN = Old Man
    My signature picture was taken by ME! Not by anyone else!
    If people keep quoting me in their sig, I'm going to burn this motherfucker down.
  • Jordan
    • 12913
    What are you talking about? Curvy straight? huh?
    Either way no, SRS cars will not accept another e30 steering wheel directly. You need to make a spacer.
    https://mtechniqueabs.com/
    • PeaveyBassist
      • Sep 2004
      • 3511
      The 2 pieces that come horizontally out of the middle section of the steering wheel. How big of a spacer do I need? Can I buy one somewhere?
      Will
      DaveCN = Old Man
      • hamann318is
        • 3382
        They both fit, the larger wheel is from the E34. The spacer is pretty much two washers under the nut. It's really easy to do.
        The BMW 318 is back. With a vengeance.
        • PeaveyBassist
          • Sep 2004
          • 3511
          So I can just buy washers that fit there and use 2 of them to make it work?
          Will
          DaveCN = Old Man
          • hamann318is
            • 3382
            Will
            The steering wheel is going to be closer to the stalks, but it doesn't bother me. I just went to HD, grabbed a few washers, and threw them in there. Make sure you disconnect the battery and such if you're removing SRS.
            • PeaveyBassist
              • Sep 2004
              • 3511
              So it WILL bolt right in? It will just be closer towards the dash unless I space it out a little with washers?
              Will
              DaveCN = Old Man
              • hamann318is
                • 3382
                Will
                You can do that, but then your horn won't work. The spacers go inbetween the wheel and the nut in the center cap. The nut doesn't go all the way down without the spacers. The wheel will bolt in though.
                • PeaveyBassist
                  • Sep 2004
                  • 3511
                  no horn is cool. I never use my horn....ever.
                  Will
                  DaveCN = Old Man
                  • Jand3rson
                    • 37587
                    Just so you know, the E34 M-Tech wheel is a fair bit larger than the E30 wheel, the tops of your legs will probably hit it.
                    • 87 325iS
                      • Jun 2004
                      • 277
                      I don't know how it is in Indiana, but your horn needs to work in order for your car to pass inspection in NY.
                      Amber Fire Pearlcoat 2000 Dodge Dakota R/T
                      Schwarz 1991 BMW 535i [Daily Driver]
                      Dark Currant Pearl 1996 Acura Integra GS-R [For Sale]
                      Orientblau Metallic 1994 BMW 740i [Sold]
                      Alpinweiss 1987 BMW 325iS [Junked]
                      • Jand3rson
                        • 37587
                        Horns are dumb. All a horn does is say "screeeeeeeeeew yoooooooou".
                        • hamann318is
                          • 3382
                          Not if you get those cool horns like the General Lee. :)
                          • BS87
                            • 1606
                            Yeah, leave your horn not working, then fail inspection :roll:
                            • PeaveyBassist
                              • Sep 2004
                              • 3511
                              So the one like Jordan's is the one to go for? and btw... we dont have inspection ;)
                              Will
                              DaveCN = Old Man
