Straightening out using the steering wheel
  • mamzak
    • 883
    I just got my car aligned, but the wheel is like 2-3 degrees off center. I know it's not a big deal but I'm super OCD about stuff like this so I want to get it fixed. I could just take it back and have him adjust it but I would feel like a big cooter asking for a 2 degree steering wheel change. Can I just take the steering wheel off and center it that way? That should be fine right?
    All girls fuck but not all girls fuck around with combustion engines.
  • evil_twin
    • Nov 2007
    • 2965
    You can take the steering wheel off and straighten it that way, but if they did the alignment and didn't 'test drive' the car and the steering wheel is crooked I would take it back
    Paypal: vdang5@gmail.com
    Delta Auto Care
    2875-C Towerview Road
    Herndon, VA
    703.435.1375
    My Feedback Thread: Evil_Twin
    • grantlacey11
      • Jan 2009
      • 680
      yes. 22mil socket. just dont over correct it!
      • woodisgood
        • 1087
        Be sure to have the key in the ignition, if your steering is locked the wheel won't come off.
        • JJ1
          • Oct 2009
          • 176
          you should take it back. they were half ass with the alignment. check the the speck sheets too. if you adjust the steering wheel the rack will be off centered. it shouldnt matter if its only a little and you dont have a progressive rack (stock e30) but you paid for a service it should be done right. good luck!
          • mrsleeve
            • Mar 2005
            • 16386
            12mm wrench.
            If its crooked to the right, crawl under Pass side and loosen the nut that holds the adjustment sleeve and turn the sleeve a 1/2 turn in. tighten up the nut, go to drivers side and repeat but turn it 1/2 a turn out. (If its crooked left do opposite this procedure).
            Go for a quick trip around the block and see if that fixed your issue, if not repeat as necessary till you are happy with it. Just make sure you turn each tie rod equally or you will lose you toe, but thats a easy fix at home as well with a tape measure
            Originally posted by Fusion
            William Pitt-
            • SlapDash
              • Jan 2009
              • 675
              You can do it yourself, but take it back. I am sure you paid dearly for the service.
              www.slapdashracing.com
                • 34839
                take it back. or make them pay for another shop that has a clue to realign it.
