How to ceramic coat?
  • diegom6
    • 4447
    Was wodering how hard/expensive would be to get a ceramic coating process....from what I know, down here nobody does it or the only company that does this job, makes a crappy job and looks horrible that ceramic coating.
    Not sure if I need a big ass oven, the ceramic base if it's costly, etc etc. I would like to ceramic cot some parts of my cars, but at the same time was thinking that I might make some profits of this if I sell the service.... does someone know about this stuff?
    Thanks for any input.
    -Diego
    Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
  • jaywood
    • Jul 2010
    • 4528
    The size of the oven depends on the size of your parts. If you're doing a car frame...then you need a huge oven. But if it's just a small tube then you can use a kitchen oven.
    As far as the process goes......
    Remove all oils/dirt.
    Sand/sand blast
    Wipe with lint free cloth
    Place part in oven to "out-gas" it (removes all water/moisture) at about 400 F for a half hour.
    Hang part, don't touch with bare skin (super hot, and puts oils back on the part)
    Make sure paint is mixed
    Spray part
    Let air dry for 15 minutes
    Place in oven at 175 F to out-gas again for 20 minutes
    With the part still in the oven, crank it up to 500-700 F and cure part for an hour.
    Let air cool
    Polish
    You're done!
    Costs: 4 oz:$18.99 (for chrome)
    • blocke
      • 1305
      OP what parts are you doing? Wouldn't powder coating be a more viable option?
      Parts Wanted
      The Never-ending Resto Mod
      • diegom6
        • 4447
        Cool tip man! I appreciate it.
        I would like to coat my turbo header, turbine housing, downpipe, etc. Also my s14 OEM header like this one and few other parts:) I think the black ceramic coat support higher temps, for example, turbo applications and the chrome type more for the N.A. engines, however the N.A. engines also get the header glowing with long runs....
        • MC Hammered
          • Jul 2008
          • 2076
          Is your turbo header/exhaust manifold cast or tubular steel?
          My 1989 e30 s52 Touring... this is Betty
          My 1989 325i vert (sold)...this is Nina
          My 1991 M5 (sold)... this is Veronica
          Photo comparison: OEM vs aftermarket windscreen for a convertible
          • Farbin Kaiber
            Lil' Puppet
            • 29502
            Need a pretty mean ass oven to get 700 outta it.
            • diegom6
              • 4447
              Tubular steel.
              • MC Hammered
                • Jul 2008
                • 2076
                You might want to reconsider ceramic coating the tubular manifold.
                I had my exhaust manifold coated with Swaintech White Lightning ceramic coating and it did its job a bit too well and turned the stainless steel into a brittle material
                Link to the thread is here: http://www.audizine.com/forum/showth...Now-with-video!!!
                • diegom6
                  • 4447
                  Thanks for the info.....then I guess nothing is good but exhaust wrapp only?
                  • MC Hammered
                    • Jul 2008
                    • 2076
                    You could wrap it if you want but I don't think it is worth the effort.
                    Wrapping it also hides any hairline cracks from being viewed when you do a visual inspection.
                    • diegom6
                      • 4447
                      That's true for that matter I have "ears" that waffleswaffleswaffles sa good job when a crack or some cracks are present when the parts are wrapped;) Already experienced that couple of times.
                      Oh well look slike ceramic coating is not the ultimate source for this subject with 100% good results.:(
                      • einstein57
                        • Jun 2007
                        • 10780
                        I had some long tube headers that were jet jot coated. Not sure if its any different then regular ceramic coating. Anywho it worked great. I would not try it on thin tubes though. Mine were stupid thick and weighed more then the factory cast setup.
                        www.gecoils.com
                        • payney8
                          • Jun 2007
                          • 899
                          Depends on thickness of the metal really. Id go ceramic coating if there of a decent metal and your getting it up in the temps otherwise it isnt really worth it.
                            • 34834
                            Sand/sand blast
                            Spray part
                            Let air cool
                            Polish
                            You're done!
                            seriously? I know where I can get old ovens really cheap..
                              • 34834
                              interesting. Also noticed it's only coated on the outside. I wonder if that has something to do with it?
                              that's also a *really* ugly coating. lol
