Help No Power Going To Coil
  • bimmer206
    • 237
    My car wont start, it turns over but doesn't start. I checked for spark got nothing so i then checked for power after the coil and again nothing, so i then used a multimeter to see if power was even going to the coil and there's none.
    • Which fuses and relays are specific to the ignition system?
    • Is there a fuse able link that i should check?
    • What are your other thoughts to why the coil is not getting power?
  • b*saint
    • 3794
    You dont have a schematic?
    Ma che cazzo state dicendo? :|
    • ZekeTheSneak
      • 1562
      check CPS (crank position sensor), that was my problem
      • Adrian_Visser
        • Jun 2006
        • 2823
        Nope that wouldn't affect power to the coil. Just if the DME switches ground and triggers the coil.
        OP go to wedophones.com and DL the ETM (electrical troubleshooting manual) and read the diagrams.
        It wouldn't hurt to let us know what year and model of car you have to begin with as well.
        '89 Alpine S52 with goodies
        • SEdgell
          • Jan 2008
          • 348
          #2 Main Relay
          • b*saint
            • 3794
            An M20 has a distributor and rotor doesnt it? Or ECU controls spark? Damn its been a while since I wrenched an M20.
            • Adrian_Visser
              • Jun 2006
              • 2823
              Yeah it has a distributor and rotor and yeah the DME controls spark. Electronic distributor ignition, the DME opens the primary circuit by switching the ground instead of having breaker points do it.
              OP the green wire (at least it's green on an 88, I just randomly chose an ETM to look at) is the positive to the coil, it comes from the ignition switch. I would check the connection on the ignition switch itself. Do your power locks work?
              • b*saint
                • 3794
                So the DME just enables the voltage to the primary via some sort of relay?
                • Adrian_Visser
                  • Jun 2006
                  • 2823
                  No the ignition switch gives a positive 12V the DME opens the ground side of the primary circuit. Then Optimus Prime show up and transforms 12v into 5000v and shoots it out of the rotor.
                  • Cabriolet
                    • 9620
                    Pre 88 cars have a position sensor on the flywheel, on the transmission housing. if the pick-up is bad or the raised mark got knocked off. this issue will occur.
                    Much wow
                    I hate 4 doors
                    • Adrian_Visser
                      • Jun 2006
                      • 2823
                      OMFG read my first post! And maybe a wiring digram too well your at it.
                      • blueapplesoda
                        • Dec 2005
                        • 1904
                        check OBC code relay if you have a 13btn obc
                        under the d/s dash
                        that was my problem
                        sticky/failed relay means no power to the coil
                        • bimmer206
                          • 237
                          Car is 1986 325 with a 6 button OBC (auto) if it helps.
                          • Adrian_Visser
                            • Jun 2006
                            • 2823
                            under the d/s dash
                            that was my problem
                            Interesting I never knew about that.
                            • Cabriolet
                              • 9620
                              on these car the no power will go to the coil if the engine position sensor is not triggered.
                              i know this because it happened me
                              Much wow
                              I hate 4 doors
