Help No Power Going To Coil
Is this car an e or i, please give us the last seven of the vin. Reference senders are relevant if it's an e other wise they don't exist unless it's an M3.Comment
So it turns over you just get no spark correct, it the transmission reference sender most likely. E's and M's have two of them one they start acting up they can be hard to diagnose. Also another member mentioned the dreaded cam being tossed off the flywheel, That I hope has not happened.Comment
Correct no spark, is there a way to verify if one of the sensors is bad? it now seems relevant to mention that I believe I have a chipped tooth on the flywheel and when I go to start the car it will randomly make a metal on metal screeching sound and not catch. Could this throw the cam off?So it turns over you just get no spark correct, it the transmission reference sender most likely. E's and M's have two of them one they start acting up they can be hard to diagnose. Also another member mentioned the dreaded cam being tossed off the flywheel, That I hope has not happened.Comment
It doesn't affect the cam one bit. It's an index tooth, every time it comes around it says fire...think of cam mesh they have to come together at same time to achieve the goal.
You can check the reference senders they need to be ohmed out with a digital volt meter. Download a copy of the the ETM from Wedophones as mentioned and go from there it's easy. Or search here for flywheel reference senders on Eta's.
I know your new but having mentioned it was an eta would have alleviated some silly bicker between members.
Tell us how things went when you get it done.Comment
Don't know your age but there is always a trade school. Days of apprenticeship are long gone for the most part.Comment
I apologize for the bickering.
OP in your original post you stated that you have no power going TO your coil is this correct? I.e. the the small green wire does not have ~12v with the key in the run position?
Can you please confirm yes or no.
'89 Alpine S52 with goodiesComment
