Required E30 tools
  • KennyT
    • 542
    Required E30 tools
    What tools are must have for working on E30's. I don't have a large set of tools yet and I'm trying to figure out what I need, not just what would be nice.
    Stereo removal tool was the first BMW specific thing I have purchased. What else do I need?
  • drumad
    • Aug 2009
    • 1700
    metric everything
    pipe wrench
    torch
    wd40
    pb blaster
    dremel
    drill
    vice grips
    bfh
    a shit ton of various all thread/nuts/washers (for pulling bullshit)
    huh?
    2008 335i - n54b30
    1991 318i - m52b28
    1994 fzj80 - LAND CRUSHER
    • StereoInstaller1
      GAS
      • 22679
      Test light, DMM, crimpers, stethoscope.
      Closing SOON!
      Thanks for 10 years of fun!
      • pawi30
        • May 2007
        • 1091
        thin 32mm wrench
        2" deepsockset EDIT: 12mm
        torx set
        jack
        x4 jack stands
        Originally Said by Bob Marley
        "BMW make pure trouble!"
        • KennyT
          • 542
          Already have the electrical kit (two years in electrical engineering), along with most of what has been mentioned. I'm looking for the various oddball tools, like what pawi mentioned.
          pawi - What do I need the 32mm wrench and 12mm socket for?
          • 87-325ic
            • Apr 2006
            • 1198
            32mm is for the real trans flange and seal. probably other stuff too.
            get a bentley, and a 8 10 and 13 mm socket and you can do almost everything.
            dont forget the bmw toolbox screwdriver.
            dont forget the valve feeler gauges too.
            • pawi30
              • May 2007
              • 1091
              For timing belt replacement.
              12 mm for crank bolt disk
              32mm for fan clutch, get it from a bike shop
              • browntown
                • Jun 2004
                • 3524
                30mm and 36mm thin wall sockets for axle nuts. Female torx sockets for transmission bolts. Hex metric sockets for tranny and diff drain plugs. Long 8mm hex socket for axle flange bolts. 11mm flare wrench for brake lines. Gearwrench's in at least 10, 13, 17, and 19mm. The 32mm wrench is for the fan clutch, but I've had success using a big adjustable wrench. I'd start thinking about air tools if you think you'll be doing much suspension work too. I think the 22mm socket they're talking about is for the front control arm - there are a few different methods for that.
                Other than that, a good selection of short and deep metric sockets with extensions / wobbles/ universals in 1/4 and 3/8 drive should do most things. You'd be surprised how much of the car you can tear down with a 13 and 17mm wrench
                Don't buy harbor freight.
                • KennyT
                  • 542
                  Tools are all craftsman or crescent, only thing harbor freight is the engine hoist.
                  The parts car is almost torn down, just left to the engine, rear section of driveshaft, diff, and then suspension/steering.
                  I'm going to need the 180* pick for the bitch clip.
                  • sharky
                    • Jan 2005
                    • 2672
                    Bfh
                    • KennyT
                      • 542
                      Will a 5lb do? Or do I need a 10lb sledge?
                      • bimmerpirate
                        • Feb 2007
                        • 561
                        5lb deadblow hammer is always good.
                        a big set of slip-jaw pliers are good for lots of things too.
                        • McGyver
                          • 4636
                          bitch bar and 36mm socket for wheel bearings.
                          • mike87
                            • 300
                            lots and LOTS of pb blaster. assuming there will be rust, which there likely will be :D
                            • StereoInstaller1
                              GAS
                              • 22679
                              If you are the typical EE, you have shit crimpers. Don't fuck around, get ChannelLock, they are the best, better than SnapOn..
                              One really useful little oddball toy is called the Skewdriver. If your screw gun is smaller, you can use the standard duty...but it will cut the hassle of a heater core install in half.
                              Closing SOON!
