Guage swap??????
  • Coujer
    • 51
    Guage swap??????
    Okay so I just bought my first e30. Its a 325es with a 325i engine and trans in it, the guages are original so it doesn't have the gauges from a 325i, would I be able to swap them or is it not worth it? Thoughts? Suggestions?
    Thanks
  • kronus
    • Apr 2008
    • 13029
    Yeah, you can swap them.
    cars beep boop
    • 325ix
      • Aug 2009
      • 7783
      Yeah but, the redlines will be different.
      • kronus
        • Apr 2008
        • 13029
        You also have to swap the coding chip. In Motometer clusters, it's a white block thingy on the lower front right of the cluster, in VDO clusters it's a black pin in the back of the tach.
        cars beep boop
        • Coujer
          • 51
          So its not plug and play. Cause right now my tach only goes to 5k, but I do have a 325i motor/tranny so I know its not correct.
          • kronus
            • Apr 2008
            • 13029
            It's plug and play. The coding chip/pin is easily inserted and removed.
            I installed a 7K rpm tach into my ETA cluster yesterday. Works fine.
            cars beep boop
