I am a dumbass
  • Strelok
    • Jan 2010
    • 280
    I am a dumbass
    So today I set out to replace my fuel injectors. I (thought I) depressurized the fuel system, by starting the car, then removing the fuel pump relay as it was running. I then set to work removing the fuel rail. It didn't want to budge from under the manifold, so I got the brilliant idea of "Hey, I'll just take the injectors off the rail." I removed number 1 after a bit of struggle. And fucking gallons of gas comes deluging out.
    I'm not entirely sure if I removed the wrong relay, or if there was just that much extra, but either way I feel like a fucking moron. The entire front side of my engine is soaked in gas.
    so yeah, wat do
  • jasonsnoddy
    • 1900
    Burn it off
    Originally posted by stewie30luvr
    ooo cause i was fixing my chain tensioner and there was a black widow on the radiator so i killed it
    Originally posted by JakeP
    with a coathanger
    • MikeDE
      • 1873
      Originally posted by Strelok
      I am a dumbass
      The first step to recovery is admitting you have a problem, good for you.
      -03/2005 E46 330D Touring 6spd(204hp/410nM) Sapphire Black/Naturbraun Sport...300k KM & 35mpg(mixed)
      • tg318is
        • Jun 2008
        • 2052
        Originally posted by jasonsnoddy
        Burn it off
        This
        Tim.
        • Eecen
          • Jun 2010
          • 1235
          Why bother posting this?
          Just wait for it to evaporate..............
          • quikveedb2
            • Sep 2007
            • 2258
            i hate to admit this, but i once was a part of a similar, slightly more harebrained experience; having some trouble starting a freshly built motor a friend & i though the ignition system to be in good working order & were checking for fuel. the car had been turning over rather (very) tight by hand but with a mechanical fuel interjection system it kept getting gas, presumably, and could be flooded. so we removed the spark plugs to flush the cylinders, and lo and behold the fully functional ignition system ignited said gas as it erupted from the head, lighting both the motor, and the ceiling of the garage on fire. a fire extinguisher made short work of it, and both garage & motor were unscathed. thus concluded our test for spark...
            long story short; almost burned car & garage, saved it all, re-machined crank, done.
            /coolstorybro
            You know why you're drinking that Pabst? No its probably not because it was the first beer you grabbed. It's because you're a winner.
            • Danny
              • 14216
              Correct
              • McGyver
                • 4637
                so by the time you would get an answer (or even finish typing this on r3v) all of the gas would have evaporated and your problem would be gone.
                why didnt you just fap?
                • downernsp
                  • Mar 2008
                  • 1932
                  Camp fire!
                  • Eecen
                    • Jun 2010
                    • 1235
                    This made me laugh, nicely done
                    • pharow
                      • Jul 2010
                      • 1021
                      you remove fuse #11 i think. let the car run stop. then try to start it a few time after that.
                      i had to do it today.
                      '02 Outback wagon
                      '87 325is 5sp
                      '93 Kawasaki ZR1100
