Is there a trick for...
  • KirkerBezerker
    • 441
    When you are mounting your wheel back onto your car, is there a trick to make it easier to get the holes in the rotor to line up?
  • KenC
    King of Kegstands
    • 14396
    Use the alignment tool in the trunk tray.
    Originally posted by Gruelius
    • KirkerBezerker
      • 441
      Haha i dont have any of the tool kit. I guess i should probably look into getting one.
      I was able to get 3 of the bolts to tighten down but 1 of them just spins anyone have this problem?
      • bmw325csi
        • May 2007
        • 4045
        you probably need a new hub if it spins freely, you might be able to get away with re-threading but you would need a different bolt.
        harry/harout
        • KirkerBezerker
          • 441
          So i would have to replace the hub and the bearing right?
          • Fusion
            • Nov 2009
            • 3659
            Easier to just put some loctite on the back of the rotor. Just enough so that when you need to replace it you can just smack it with a hammer.
            • Adrian_Visser
              • Jun 2006
              • 2823
              Since you are most likely going to pull the inner race of the bearing out with the hub you better have the bearing on hand too. Front or rear wheel?
              '89 Alpine S52 with goodies
              • KenC
                King of Kegstands
                • 14396
                Yeah, you stripped one. Buy a new hub... It's the whole hub/bearing assembly.
                • KirkerBezerker
                  • 441
                  I like the loc tite technique for sure! It is my rear drivers wheel.
                  • KirkerBezerker
                    • 441
                    How long do you guys think i will be able to roll on just three lugs with the 4th loctit'd on?
                    • george graves
                      • 20003
                      Hang on. Let me do some math.
                      3 lugs / 4 lugs. Carry the 7, times pi....er...integrate with respect to darwin...dd/dt from 1 to knucklehead.
                      Ah yes! The answer is 1.32 years.
                      Originally posted by Matt-B
                      • Adrian_Visser
                        • Jun 2006
                        • 2823
                        Ever replaced a rear wheel bearing before? You need a special press tool to do it.
                        Just long enough for your wheel to fall off, no more no less.
                        Do you really think loc-tite has any tensile strength at all? It's fucking glue!
                        • accident
                          • 7303
                          also if you glue the bolt in place it will essentially be there for looks. since the threads are stripped it will have no torque.
                          Moral of this story?
                          • KirkerBezerker
                            • 441
                            Haha well i didnt think i could actually continue to DD on it just wanted to know if i could limp it over to the shop?
                            • Fusion
                              • Nov 2009
                              • 3659
                              I thought you meant the small bolt that holds the rotor to the hub.
                              Nevermind what I said.
